Question about Bose 3 2 1 GSX System
Adding Spaekers Can I add speakers to my Bose 321 system, I have 2 additional speakers?
  • jaynowak Jan 12, 2009
    Yes I have two additional speakers and was wondering if there is a way to add them. They are the same speakers that goes with the system....
  • sgediman Mar 16, 2009
    I am wiring my deck for speakers how can I connect them to my bose 321 sydtem inside the house
Are you able to add speakers to the Bose GSX 321 system?
Posted on Jan 12, 2009
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Boise
What model of TV are you hooking the Bose system pls? Alternately, determine if the TV you are hooking it into has a pair of white and red RCA connector marked Audio OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 14, 2008 | Bose 3 2 1 GSX System
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Jun 18, 2009 | Bose 3·2·1 II System
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
I'd like to add two speakers to my older 4 pin Bose 321 system. Can I buy adaptors to split off the two small front speakers to run two additional speakers to the rear of the room?
is there any connection for 2 more speakers?
if not there is no real way to make it surround sound . however you can double up the speakers with the front ones.
but you loose sound quality and it wont be true surround sound. but you can give it a try
Apr 21, 2009 | Bose Companion 5 Multimedia Speaker System...
Additional speakers for 321 system
No. You would need some kind of audio out connections on the back of the media center. The only audio outs it has are the
Acoustimass® Module – SPDIF connector.
Unless you were to hook up an amp before the Bose media center. In other words, you could run your TV to another amp's line in. You would hook up additional speakers to this other amp, then run audio line outs to the line in of your Bose media center. Some stereo amps have a line out or record/tape out, it is from here that you would run the cables to your Bose media center line ins. The disadvantage to doing it this way is you would have to plug all your media devices (dvd, tv, etc) into this amp first and your Bose remote wouldn't let you switch between devices. If your media devices you have offer digital audio, then you would want an amp that also offers a digital out for the best sound. Otherwise you will end up with analog out from this amp to the Bose media center and thus lose any of the digital signal information like surround information. So there isn't much point in doing this. If your gonna get an amp that has all the digital in's and out's, you might as well just use it with new speakers and forget the Bose system you have.
Jun 06, 2008 | Bose (321GS) System
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Bose 3 2 1 GSX System Logo
1,508 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
