Question about Pioneer VSX-C300 Receiver
Center speaker not working in Pioneer VSX C300
Hello, I have a Pioneer home theater system with VSX C300 receiver. A week ago, loud static and other crackling noises started coming out of the center speaker. The receiver would automatically turn off sometimes when a loud sound comes, and may turn back on again by itself. This happens whether you are listening to the radio on the receiver, or playing satellite TV sound, or playing a DVD. Now the center speaker only loud static, no meaningful sound. If I plug in any other speaker with any other wire in the center channel slot, the same static comes out of that speaker too. The center speaker works fine on other channels. So it is not the speaker itself or the speaker wire. Anything I can do? I plugged in a multimeter in the center wire slots to see if there is a short circuit, but it is not showing any short circuit. Any hope? Everything else is working fine so you hate to throw away the whole system. Thanks!
  • bernieeccles Jan 04, 2009
    Yes, I have a similar problem and it irritates the hell out of me.I can be listening to mine and all of a sudden loud crackling noises usually followed by an Amp Error message.
    I found that if I put something under the left front foot to sort of,jack it up twisted it sometimes helped.I have had the cover off looking for something obvious but found nothing.
    I have a feeling something is shorting and the amp switches off and then back on.I must admit it has nearly been thrown out the window !
5 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Posted on Jan 04, 2008
lynchms
  • 93 Answers
SOURCE: Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Posted on Jan 28, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
  • 222 Answers
SOURCE: connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
Posted on Jun 10, 2010
michaelhi580
  • 62 Answers
SOURCE: Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Posted on Mar 15, 2011
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
Pioneer vsx 822 k shuts down when i turn up the volume
Could be caused by a bad speaker, try disconneting speakers and see if it still happens.
Jan 10, 2014 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
VSX 60 pioneer receiver shuts down on loud action dvd
Sounds like a bad speaker or speaker that is being over-driven.
Jan 09, 2013 | Pioneer Audio Players & Recorders
Connectivity
Jun 10, 2010 | Pioneer VSX-818V-K Receiver
Pioneer vsx-519 no sound from center and surround
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Pioneer Home Theater System VSX-305 owners manual
Dear Sir/Lady
I wat to get the
Pioneer Home Theater System VSX-305 owners manual Thanks a lot
WILLIAMS
Apr 08, 2008 | Pioneer VSX-305 Receiver
Pioneer VSX-C300 Receiver Logo
311 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
