Question about Whirlpool 24 in. DU800CWD Built-in Dishwasher
Dishwasher will not fill-up with water
My dishwasher will not fill up with water. The lights come on as though it is getting power and it will drain (I put water in it manually to check). The machine was working fine until the storms hit, and lighting struck a pole in my back yard, flipping a breaker causing some of my other appliances to malfunction. I made sure that the breaker was back on and my other appliances resumed to working order except the dishwasher. Can someone help please.
  • 87 Answers
You need a new electronic module.
Posted on Jun 10, 2007
What would cause the inside of dishwasher to slowly fill with water even in off position.the water drains just fine, but after drained it will slowly start filling the bottom of dishwasher back up.
the water control solenoid unit has a faulty diaphragm in it allowing water to pass even though the power is off
replace it or turn the tap off after each use
call a technician for the proper diagnosis and repair
Jan 28, 2017 | Dishwashers
Dishwasher will fill w/water but will shut off b4 cycle begins
Have you unplugged it for about 20 minutes yet and tried again?
Dec 28, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher doesn't want to fill
Hello Dianne...I'll take a shot here.. chances are that the door interlock ( switch ) is disabling the dishwasher from starting.. it may be damaged or disconnected.. and as long as you are sure you have a water supply to the dishwasher,.. that's where I would start...If that switch is NOT made.. the dishwasher will not start... Hope that helps
Aug 16, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher
Check to see how fast water is entering the dishwasher.
They work on a timed basis with a float switch being a safety.
You may want to check how the water gets into the dishwasher and  then see if there is plugging somewhere.
Feb 16, 2008 | Indesit 24 in. D61 Free-standing...
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
114 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
