Question about Panasonic TH-50PX50U 50 in. Plasma HDTV
HDMI inputs do not work on my Panasonic Plasma TV
I purchased a Panasonic Plasma TV (model # TH-50PV80H) around a month ago. I connected a DVD player (capable of HD upscaling), a multi-media PC and a PlayStation 3 via HDMI cables and everything worked great. After 2 weeks, I could no longer connect the PC via the HDMI - the screen simply went black (but I could connect it using the VGA input). The DVD player and PlayStation continue to work for a few more days and now I can't get them to work either. At best (and after the TV's been sitting idle for a few hours), I can get a picture for a 15 - 30min, then the screen goes black again.
First, I assume that I'm dealing with some sort of hardware problem - correct? Secondly, is it possible that the PC is the cause of the problem? I've been reading on-line that you can do damage to I/O board due to the fact that the native resolution on the TV is different from a PC.
I'm hoping that there's some kind of easy fix for this since I purchased the TV in Canada before moving to Europe and I don't know if my warranty is valid (fyi, the TV has a UK plug and is fully PAL and NTSC compatible).
Thanks in advance for any help you can pass along!
  • bdh0624 Jan 02, 2009
    Update to what's written above ... I've been able to connect my PS3 to
    the HDMI input for over three hours this morning (and counting), yet
    last night it would only work for 15min before the screen went black.
    Is this consistent with a faulty signal card?
    Thanks for the quick response Drumbanger (I'm not sure how to respond to you directly, so I'm adding this comment to your proposed solution).
    FYI, the TV model is actually a TH-50PV80H, not a TH-50PX50U (but I'm sure this doesn't really matter).
    Genius:
  • 1,199 Answers
This sounds like the signel board has went out and will need replaced! I checked an panasonic tells me that your warrenty is still good even if you move!
Posted on Jan 01, 2009
    President:
  • 624 Answers
This is a failure in the TV input circuit. The buffer IC used in the HDMI input circuit is failing for some reason. It could be the supply voltage for the IC has an intermittent component causing it to fail after it has been working for a while, or it could be the IC itself breaking down after it gets hot, or maybe even a bad solder connection failing at intermittantly. It must be checked by a technician with the proper tools to isolate the problem with any certainty. Anything else at this point is just guess work. From your description of the problem it is very unlikely to be a menu setting or a problem that resetting the unit will fix.
Posted on Feb 15, 2009
  • 15,935 Answers
Definately a hardware problem, however it is with the inputs of the TV. This is not a end-user fix. Contact panasonic. your warranty should still be honored if there are panasonic authorized repair centers in the country you now live in.
Thanks for using FixYa - a FixYa rating is appreciated!!
    Sergeant:
  • 250 Answers
First of all check out the cables are the proper.also replace the cable and check or check out any other device with the cables and confirm.also it can be the loose connection issue internally.jusdt get the system check withy a multi meter to locate the fault.
  • Panasonic Master
  • 19,396 Answers
Check if the TV has a configuration menu for HDMI devices.
Try also unplugging al devices from power and plugging them back with HDMI cable in , sometimes this can solve the problem.
  • Ginko
    Ginko Feb 15, 2009
    If this does not work, there is a small HDMI input board (signal board ) that sometimes gets damaged when you connect the HDMI cable with devices on.
    The most likely is a setting problem, a wrong resolution on the receiver/dvd , or the need for a better HDMI cable.
    In some case you get a damaged HDMI input board.
    Let me know how it goes.
    Thanks
2 Suggested Answers
  • 679 Answers
SOURCE: we are in Europe and
Yes. Its PAL System capable.thanks
Posted on Jan 19, 2011
Panasonic TH-50PV80H
It will be best to contact the authorized service center for Panasonic at your town. Some critical parts to Plasma displays will be very difficult to get by open electronic spare part market.
Jan 16, 2013 | Panasonic TH-50PV80H 50 inch Multi-System...
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
H1005 error
I played with going to another HDMI outlet and then back to the original and it seems to quickly reset itself and the message dissappeared!
May 23, 2009 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
Mar 25, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Panasonic TH-50PX50U 50 in. Plasma HDTV Logo
3,338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
