Question about Clarion XMA1-RET Cassette Player
Changing Stations How do I make the darn thing change from FM to AM. Just can't seem to make it switch, I can go from FM to cassette, I can adjust the volume, turn it on and off, change the clock, adjust the left/right speakers, but can't figure out how to get it back on AM.
Each time you push the band button the folling should happen fm1 - fm2 - fm3- am - fm1
regards hope this works
Posted on Jan 03, 2009
Can be fixed an Original Skoda Fabia 2003 radio that gets stuck changing stations?
Anything can be fixed. I would check the front panel switches first.
Jul 12, 2017 | Skoda Cars & Trucks
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
2003 Hyundai Accent ... Model HM-5064 Serial Number 01106567 How do I find fm stations for my IPod on this systems...i cant seem to enter manual stations,.
Hi
I have the same problem as I want to use a fm transmiter to use my ipod. I can't believe that there is not a way to manualy change the stations. It only goes to preset stations. The most stupid thing I have ever seen on a car radio. Does anyone have an answer to this? please help us
Jan 18, 2010 | 2003 Hyundai Accent
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
Gears not changing quickly enough. and then changing 10 to 15 seconds later after clicking shifter . when they eventually change they seem to thud down the cassette . no promblems putting them back up the...
Two things to this problem.
1. Clean your drivetrain REALLY, REALLY thoroughly with a good degreaser and a bristled brush. All of it. Clean the derailleurs, the chain, the cables. Once it is all cleaned up and dried off, lubricate the chain and the cables ONLY.
2. Shift your bike into the highest gear and release the cable. Pull it taut and re-tighten it. Flip it over and shift into your middle cassette cog while cranking the pedals. Use the barrel adjuster on your rear shifter to get the jockey wheel on the cassette aligned over the correct cog.
This was an abridged guide to rear derailleur adjustment because it sounds like it was more grunge in the cable or derailleur than anything else, but i'll check back and if this solution doesn't work out, i'll give you tips on a far more thorough overhaul. Just remember a clean drivetrain is a functional drivetrain, and the cables and chain are the only thing you are supposed to lube.
Hope this helps,
matt
Sep 16, 2009 | Sram X.9 Rear Derailleur
Aiwa CR-LD120 AM/FM Radio?i program my radio stations, but when i have to change batteries i lose all the stations and have to reprogram them
This is a common problem when disconnecting power!
Try buying an ac adapter at your local pharmacy or radio shack and plug it in before changing batteries
Feb 08, 2009 | Aiwa CR-LD120 AM/FM Radio
FM channels
since the 70's when they started, FM radios in cars have only showed like 101.9 and 102.1 in odd number tenths-of-Megahertz only, with a few rare exceptions. There are some high cost receivers that will show odds and evens. Your 102 station is really either one of like 101.9 or 102.1 for your Pioneer.
Apr 15, 2007 | Pioneer KEH-P2800 Cassette Player
Clarion XMA1-RET Cassette Player Logo
64 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
