Question about Kenmore 54362 / 54364 / 54369 Side by Side Refrigerator
Refridgerator I am getting ice but not water I replaced filter and still cannot get water out of my fridge I used hair dryer but it didn't help please help Thank you
  • 126 Answers
Did you check the resevoir in the fresh food section it may be frozen. There is also a possibility that this refrigerator has a dual valve one sends water to the ice maker the other to the water dispenser it may be bad. I tried to look it up but the model number listed would not come up I think you are missing numbers best to get a complete model number from the refrigerator not the manual.
Posted on Jan 02, 2009
Replaced water filter, dispensing valve on frigidaire gallery side by side still no ice or water
It may very well be frozen. Some of those fridges have problems with the line freezing because of the way the line runs. The one way to tell would be to empty fridge, unplug, and let sit to thaw. Opening freezer/fridge doors will shorten the process. You can Google your exact model number also, and find out how your lines run and use a hair dryer on that location.
Mar 07, 2016 | Frigidaire Refrigerators
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Feb 02, 2010 | Hotpoint Freezers
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water filter question
WOW! I'd say that the filter is definately due for replacement.
The manufacturer recommends the filter be changed every 6-8 months, as with ice and water dispensers in the door, folks tend to use the chilled water and ice more often, hence you get alot of gallons of water thru the fridge each month.
Once you replace the filter, you'll need to flush out the lines, (see the instructions with the new filter) to get rid of any loose carbon in the filter element, but once you done this, you should also notice better water flow and better tasting water and ice cubes too.
I tend to change my ice/water filter on my fridge every year when I change my smoke detector batteries. That way, I don't forget, sort of like my personal "once-a-year" house task list to change batteries, filters, resetting timers, etc., etc.
It's a good idea to change these smaller filters at a minimum of once a year, as they are no longer providing the filtration you want, and can actually be letting some of the contaminents fow out and into your water and cubes.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | KitchenAid KSSP48QMS Side by Side...
Water lines i think are ok but cant get water or make ice
Check the following:
See if the fridge has a water filter...it could be plugged and need replacement...check your manual for the location and replacement procedures
Check the inlet water line to the ice maker...it could be frozen...a hair dryer can be used to thaw it out and get the ice make to work again...be careful and don't overheat the ice maker inlet water line.
Make sure the water line is ok and not obstructed or kinked
Check the ice maker water valve to be sure it opens and isn't clogged
Cycle the arm on the ice maker and wait to see if it will make ice again
Jul 05, 2009 | GE Refrigerators
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Water Leaking
The defrost drain is clogged up. I can't say much more because you didn't supply the model #
This may be a drip catch that you can get to from inside the refer or it may be the big tube on the backside of the box.
You may have to take the freezer apart and use a hair dryer to thaw out the ice.
Model numbers are important!
Jan 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 54362 / 54364 / 54369 Side by Side Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
