Question about Fujitsu 24R1 Air Conditioner
Water leaking into the house - model AOT24RWGL
Our split system airconditioner has started leaking water from the condenser (opposite side to the outlet pipe) into the house. Filters are clean. The drain to the outside appears to be clear.
Is there any way that it would have realigned itself on the wall?
  • 334 Answers
Either the drain line is clogged, or there is a hole in the pan.
Get a powerfull wet/dry shop vacume.
Attatch it to the end of the drain pipe and seal it tight and pull out any dirt, mold crud blockages.
Take the panel off so you can access the drain pan under the evap coil. Clean that out as well with the vac.
Once its nice and clean, poor a gallon or so of water into the pan bein g carefull to not pour to fast.
Make sure that the line is drainign well and look for any spots where there may be a crack, hole etc in the drain pan where water may leak out
Posted on Jan 01, 2009
What does it mean when airconditioner leaks water in the house down the wall
Make sure it is angled slightly toward the outside so the condensation which comes from the evaporator leaks outside.
Mar 15, 2011 | Heating & Cooling
Location of thermostat on 2002 olds alero 2.2
Thermostat Removal & Installation 2.2L Engine To Remove:
  1. Remove the exhaust manifold. If equipped with an automatic transmission.
  2. Drain the cooling system.
  3. Remove or disconnect the following: chevy_cav_02-04_tstat.gif
    • Thermostat housing to water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    • Thermostat housing to water pump feed pipe.
    • Thermostat.
To Install:
  1. Install or connect the following:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt.
      1. Tighten bolt to 89 in lbs (10 Nm).
    • Exhaust manifold if equipped with an automatic transmission.
  2. Fill the cooling system.
2.4L Engine To Remove:
  1. Drain the cooling system.
  2. Remove the exhaust manifold heat shield.
  3. Remove the coolant inlet housing mounting bolts through the exhaust manifold.
  4. Raise and safely support the vehicle.
  5. Remove the coolant inlet housing stud from the oil pan.
  6. Remove wheel and tire assembly.
  7. Remove the engine splash shield.
  8. Remove the mounting bolts from the transaxle-to-engine block support. Remove the support.
  9. Remove the coolant housing pipe.
  10. Remove the thermostat.
  11. Clean the mating surfaces.
To Install:
  1. Install the thermostat.
  2. Install the coolant housing pipe.
  3. Install and secure the transaxle support-to-engine block mounting bolts.
  4. Install the engine splash shield.
  5. Install the wheel and tire assembly.
  6. Install the coolant inlet housing stud to the oil pan.
    • Tighten to 19 ft lb (26 Nm).
  7. Lower the vehicle.
  8. Install the coolant inlet housing bolts through the exhaust manifold.
    • Tighten the coolant inlet housing bolts to 10 ft lb (14 Nm).
  9. Install the exhaust manifold heat shield.
  10. Fill the cooling system.
  11. Inspect the system for leaks.
3.4L Engine To Remove:
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat.
To Install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts.
    • Tighten the thermostat housing bolts to 18 ft lb (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet.
    • Tighten the fittings to 15 ft lb (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks
Oct 14, 2010 | Oldsmobile Alero Cars & Trucks
Where is the thermostat on a 2.2l ohc engine?
Removal & Installation 2.2L VIN 4 To Remove:
  2. Remove the lower radiator hose from thermostat housing.
  3. Remove the thermostat housing bolts and outlet.
  4. Remove the thermostat.
  5. Clean the mating surfaces.
To Install:
  2. Install the thermostat housing and bolts.
  3. Install the coolant housing bolts. Tighten bolts to 14 Nm (10 ft. lbs.).
  4. Install the lower radiator hose to thermostat housing.
  5. Fill the cooling system.
  6. Inspect for leaks.
2.2L VIN F To Remove:
    • Thermostat.
To Install:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt. Tighten bolt to 10 Nm (18 in. lbs.).
    • Exhaust manifold. If equipped with an automatic transmission.
2.4L VIN T To Remove:
  3. Remove the coolant inlet housing bolts.
  4. Lift vehicle.
  6. Remove the wheel.
  7. Remove the right engine splash shield.
  8. Remove the transaxle-to-engine block brace bolts and brace.
  9. Remove the radiator outlet pipe.
To Install:
  2. Install the thermostat.
  3. Install the radiator outlet pipe.
  4. Install the transaxle-to-engine block brace and install bolts.
  5. Install the right engine splash shield.
  6. Install the wheel.
  8. Install the exhaust manifold heat shield and bolt.
  9. Tighten the exhaust manifold heat shield bolts to 14 Nm (10 ft. lbs.).
Sep 09, 2010 | 2003 Pontiac Sunfire
Lg split type leaking water from bottom seams
There is a drain tray under the fins in the wall unit which collects condensed water and and drain it out through a outlet. Sometime the tray gets clogged wit the dust and thus water instead of going towards outlet gets accumulated at one place and spill over. You can remove the front cover and see this water out let and the tray. Clean it and ensure that it is connected to outlet properly. Also check your water out let pipe which throws the water out is not clogged with the muck/dirt as this the most common cause for water leakage in the machine. The condensed water has no get away,
Aug 26, 2010 | LG Heating & Cooling
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
My roof airconditioner leaks drain water on the floor.
make sure the drain is not plugged and that condensation can get under the cooling coil to the drain pan otherwise it may be condensation forming on the grill, make sure the filters and coil are clean and you are moving lots of air.
Jun 02, 2010 | Coleman Mach 15 Air Conditioner
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Dishwasher leaks at start
Is the washer not "over filling" due to the water fill vacume pipe and micro switch that shuts off the water once the correct level blocked or restricted due to fatty residue? This could also be one of the washer pipes clogged up and increasing the pressure in the fill tank.
Jan 20, 2010 | Dishwashers
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
My window air conditioner keeps freezing and leaking water does this mean i need a new part for it? the model number is FAA060P7A5
It is normal for airconditioner to have condensation. Just make sure the water don't go in the house. LOL
Aug 15, 2009 | Heating & Cooling
Fujitsu 24R1 Air Conditioner Logo
838 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
