Question about NetGear DG834G Router
Resetting password Hi Me again, sorry to be a pain in the rear. I have tried to secure my wireless connection with your instructions but it appears that the user name and password are not set to default (its not something I would have changed so I am assuming my network provider would have done this as the SSID is not default either.) If I reset the router with the little button on the back are there any settings that I should make a note of before I do this. Thanks Mark
  • markroberts9 Jan 02, 2009
    Problems all sorted, thanks for all the help. You may or may not know that the password for routers supplied by sky is "sky" the username is still admin. Thanks again
  • 104 Answers
Hello again, no problem at all! Thanks for letting me know.
If your router was actually set up by your ISP/network provider, or came with their settings, I’d recommend a visit to their website or helpline before going further.
This is because ISPs sometimes put their own firmware onto a router – most don’t do this, but some do. This makes the standard manufacturer’s manual useless for troubleshooting, and can make simple tasks, such as setting security, more difficult. I know that Sky do this, for example.
So I would not recommend a reset at this point, as you will lose the internet connection altogether until the router is set up again. Also, each ISP is different as to which settings they require to set up the router again: so again, a visit to their website or helpline is a good place to find this out.
Sorry to be negative here, but I’d rather err on the side of caution – having tried to help a someone with a Sky router, I’ve learned to tread carefully!
If you find that everything on your router is otherwise standard apart from the password – and your ISP supplies the password – you should be able to proceed as stated.
If you’d like to get hold of a standard DG834GT reference manual or installation guide by the way, you can download one from here: (bottom left)- there are also some helpful links on this page.
Good luck whatever you decide to do!
Posted on Jan 02, 2009
  • eecom Jan 02, 2009
    Oh, excellent! Thank you very much for the feedback. Glad it worked out OK for you!
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I have d-link router ,works fine ,my new laptop hp don't connect to interent ,see the network ,but unable to connect
Hi amany91,
There might be an issue on your wireless connection security settings. I would advice resetting your router to remove the password and to restore to factory settings. To do that, look at the back of your router and look for the RESET BUTTON. Then using a pin, press and hold the reset button for about 10 seconds. After resetting it, restart your laptop and then try connecting to your router again.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
ternet again.
Oct 09, 2011 | D-Link DIR-615 Wireless Router
I have a Nintendo 3Ds and I've tried to connect to the internet and I have followed the tutor instructions and get an error code 003-1101 when I test. I have an Net Gear wireless router from com cast...
Likely cause: It appears that the security settings entered into the Nintendo 3DS are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings.
Follow the instructions here for your netgear settings:
Netgear
Please rate
Aug 24, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
CAN'T CONNECT TO NET BOOK WIRELESS BUT HARD WIRE PC WORKS
Try RESETTING the Netgear router and configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My lan lines work but there is no wi-fi signal coming, it worked yesterday and for a number of years.
I know it is a pain but to determine if the D-Link is faulty, try resetting the D-Link back to the default settings and configure it again -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 28, 2011 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
I bought an Amazon "Kindle" Wi-Fi reading device
I do not recommend that you use WEP for security as this is no longer a secure method for wireless network.
Setting up a wireless network can be a bit tricky at times, but if you follow this step by step guide for Linksys routers, you will have your wireless network up and secure in no time.
It will walk you through resetting the wireless router and quickly setting up a securing your network.
Click here:
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Feb 18, 2011 | Linksys Wireless-G WRT54G Router
Can't access internet
hi this is quite simple case of resetting the router, on the back there is a reset hole, get a paper clip or something thin to poke inside it, hold it in for 15 seconds this will reset the whole system and you can start again, just start internet page up, then at top type in 192.168.0.1 then the password and the admin will be admin and password is password then you will get your menu back up and just input the details of your connection user name and password, then the rest is up to you...hope this helps
Jun 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
Laptop wont connect to wireless belkin router
If you connect the laptop wired, does it work correctly?
If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way.  If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
Mar 18, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
Aug 25, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
NetGear DG834G Router Logo
69 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
