Question about Air Hogs Havoc Heli Helicopters
My Havoc Heli got wet
It fell into a bowl of water and now when I try to fly it the main propellers spin for a second but then stop. The blue lights still flash and the tail roter still spins. Anyone know what I did or can do?
    Problem Solver:
  • 9 Answers
Must be off, air dry, or in a warm place for a few days. then fully charged.you might have damaged the battery by getting it wet, if so the only choice is replace the battery.usually dried and charged is enough though.the lights require less power to run than the motor, thats why they continue to work even though the motor doesn't. Also make sure the battery is really full.watch for the lights on the charger (controller) to cycle,new batteries in the charger take about 15 min. to give a good charge.Good luck!
Posted on Jan 26, 2009
    Problem Solver:
  • 11 Answers
Most likely you short circuited something and now it can't be fixed. I would send it back to the company to be replaced.
Posted on Jan 05, 2009
My AH-64D LONGBOW helicopter spins out of control when i try to fly it how can i fix this problem?
make sure the tail motor does not have any hair stuck in it take of the little propeller and clean it.
next adjust the trim so when your taking off so helicopter will not spin any more and your good to go
Dec 13, 2010 | Spinmaster Air Hogs R/C Ah 64 Apache Havoc...
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Problem with the back rotor.
make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Jan 07, 2009 | Air Hogs Havoc Heli Helicopters
Havoc heli flight problems
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Jan 05, 2009 | Air Hogs Havoc Heli Helicopters
Havoc heli frequency
You only need one frequency to be able to fly it. So it's working fine.
Dec 27, 2008 | Air Hogs Havoc Heli Helicopters
Air Hogs Havoc Heli Helicopters Logo
978 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
magna buff
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
