Question about MA Audio MA 1200XL Car Subwoofer
How do I properly connect the subwoofers to hit really hard? Like on the back of the subwoofer?
  • lu3y Jan 10, 2009
    very helpful.... thank you very much..
  • 3 Answers
That subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Posted on Jan 08, 2009
I need a wirimg diagram for a 1000 watt 4ohm dual voice coil
1 sub just run 1 possitave to the other an only one side to amp same for ground
Nov 10, 2013 | MA Audio MA 1200XL Car Subwoofer
Wire diagram for subwoofers
need more info,what ohm load are spkrs? are they single voice coil or dual? if dual what ohm dual 2 or dual 4? what amp are you planning to use? stereo amp or mono block? if mono block what make and model? what style box are you using,sealed or ported?
Jan 09, 2013 | MA Audio MA 1200XL Car Subwoofer
I have a ma15xq subwoofer. what power do they need to sound good.
Check the total RMS who support the speaker and buy the amplifier who fits that RMS
Aug 01, 2010 | MA Audio MA 1200XL Car Subwoofer
Blown Subwoofer
if you don't wanna get rid of it bust out your spec sheet then go here and build accordingly then rip off the old dust cap and put it back on
http://www.fixmyspeaker.com/Products.php
Mar 24, 2010 | MA Audio HK15X2 Car Subwoofer
Hay i just brought da sub on its own and dont no wat a good size amp and power needed to make dat bumpn bumpn feel...and how to connect it all up plezzzz.... fnx DJ KINGXL out
buy a bridged amp with half the power of your sub (ie 1200 watt sub use a 600 watt amp) this will stop distortion at high volume get in touch when you have the amp and i'll go through how to wire it .
Aug 20, 2009 | MA Audio MA 1200XL Car Subwoofer
I have a ma audio 15 and i 2 know how big the box needs 2 b
Hello aerickson28,
That MA need a pretty good sized box to perform properly. 2-2.5 cu/ft sealed and 5 cu/ft ported.
Here's a link to the MA Audio specification page for the HK15X2:
http://www.maaudio.com/product.jhtm?id=56&cid=16
Hope this helps.
Apr 11, 2009 | MA Audio HK15X2 Car Subwoofer
Yes i have a 1000 watt amp and when i turn it on it stays on fine until the bass hits and then it kicks off then it kicks back on and the problem reaccures
I believe you have your gain on the amp turned up to high. Try turning the gain down, or if you have a LOUD button on your headunit turn it off
Hope this helps
Apr 06, 2009 | MA Audio MA 1200XL Car Subwoofer
Ma120xe sound horrible
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Dec 14, 2007 | MA Audio MA 1200XL Car Subwoofer
6oow 12in. subwoofer
look to see if somthin got in there and if not if the subwoofer is ok you might have to much of a high signal going in to the sub. Sub are only reted for low Hz and not High Hz and if you get a high in to the sub the cole cant moves fast to me the high Hz that is getting.
The best way to fix that is with a crossover and make shour that you crossove is for lowbuypass only.
Oct 23, 2007 | MA Audio MA 1200XL Car Subwoofer
Im not sure how to hook these speakers up
answer depends on what kind of Ohm Load your amplifier is capable of as a lowest allowed setting. ie if you have a 1400W at 4 Ohm amplifier, the connection would need to be different than a 1400W at 2 ohm amplifier. also, on the speaker what is the rated ohm load per coil since it's a quad coil speaker (should say somewhere on it's box, or in it's manual. I'd assume 4 ohm per coil) we'll do that math after you get those figures in to me.
Aug 16, 2007 | MA Audio MA 1200XL Car Subwoofer
MA Audio MA 1200XL Car Subwoofer Logo
395 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
