Question about Philips GOGEAR SA6045 MP3 Player
The clock is not working while the player is off
Do i have to set the clock new every time i switch on my player???
I'm having the same problem with mine can anyone help
Posted on Apr 26, 2013
  • 8,596 Answers
It is a fluke - I can't remember exactly, but it either happens before you upgrade the firmware or after - there is no solution - you can even call Philips to verify.
Posted on Jan 02, 2009
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi
https://prezi.com/vgxxmjfbc1ya/sharp-alarm-clock-inustructions/ Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
Nov 05, 2017 | Sharp Audio Players & Recorders
Trying to set the clock but no luck
Your CD Players time can be setted by clicking on adjust switch and choose clock and rearrange the time by changing.
Oct 09, 2010 | Kenwood KDC-MP2035 CD Player
How do you start the clocks on this until?
From Eclipse tech support...
Basically, as they said: The clock is set by the GPS. The unit needs to be On.
[Quote]
AVN-5500 Setting Daylight Saving time: The clock is set by the GPS. The unit needs to be On. Push the [MENU]
button once, on the display touch the [SETUP] icon, then touch the [TIME ZONE] icon, and then select DAYLIGHT
SAVING On/Off. Push the [OK] icon to 2 times to exit. Tech Support[Quote]
So it does not appear that it can be performed manually.
I hope that helps
Mar 23, 2010 | Eclipse AVN5500 Car DVD Player
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
Cannot set time on pioneer car cd player DEH 1100 I Do not Know What to do
cut the power off to the radio. They hold the clock button in for a few seconds. the clock will show up, and should be blinkimg.Us the tuner button to set the hours, then hit the volumn button. This should switch it to the minuntes. when time is set. Push clock button again, and it should be set.
Jan 31, 2009 | Pioneer KEH-P2030 Cassette Player
Clock setting on Pioneer DEH-P77DH in dash cd player
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
Jan 04, 2009 | Pioneer DEH-P77DH CD Player
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
Clock setting
If you are willing to provide Pioneer with your email address, you can download your owner's manual here: http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_290996822,00.html
Apr 03, 2007 | Pioneer DEH-2800MP CD Player
Philips GOGEAR SA6045 MP3 Player Logo
157 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
