Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were attached to Y and W terminals. How do I wire to the new thermo?
  • 61 Answers
If the system worked before with three wires then the fan wire(green) must already be jumped to the Y terminal at the furnace. You should be able to run the red wire to Rh and Rc, run the white wire to W and run the yellow wire to Y on the new thermostat. You will not have control of the fan (ON or AUTO) from the thermostat. R is 24v from the furnace, W is the Heating circuit and Y is the Cooling circuit.
Posted on Jan 01, 2009
  • 75 Answers
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Rth2310b wiring
More than likely, this is what you have:
Red- Power- (RC/RH)
White- Heat- (W)
Green- Fan- (G)
Blue- Cool- (Y)
Usually, the only times you need more than 4 wires are:
1. You have a HeatPump system.
2. Your new digital thermostat does not use batteries, which then you have to have a common wire to power the thermostat.
May 26, 2012 | Honeywell Rth2310b 5-2 Day Programmable...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Had electrician install RTH2310B Honeywell thermostats but am getting no heat
check to make sure that it's wired correctly. R(red)power, G(green)common, Y(yellow)cooling, W(white)heating, O(orange), E(emergency)heat. Make sure that you have the correct thermostat because there is a heatpump thermostat and there is an air condition thermostat and they are wired differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
Connecting New thermostat with two existing red and white wires
sounds like a heat only system,not all stats work heat only make sure it will(should say on packing)
Dec 02, 2009 | Honeywell Programmable Thermostat Heater
How do i install a honeywell rth2310b with an old two wired one
Run the old thermostat wires to R&W or RH&W on the new thermostat
Oct 27, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring honeywell DT200(T6620B)
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
594 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
