Question about Philips Magnavox DVD/VCR Dual Player
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
This unit all of a sudden shuts it self off about 20 seconds after being turned on. The VCR has not worked in a very long time. once a tape is inserted it plays for a few seconds and then ejects the tape.
  • 4 more comments
  • Anonymous Jan 02, 2009
    I logged on to try to find help with this exact same problem! I just bought the thing yesterday and the DVD pla;yer works fine, so far. But the VCR shuts off within about 10-15 seconds of inserting a cassette.
  • srilaura Jan 02, 2009
    exact same problem as of jan 1, 2009!
  • Ajax7925 Jan 27, 2009
    I am having the same problem.. I have tried a few diffferent tapes. Each tape was at a different spot. Older tapes and new tapes. Same problem :(
  • amreilly Feb 20, 2009
    Same as Ironmike91's.
  • terpin14 Mar 01, 2009
    The unit will only stay on for five minutes or less.
  • srilaura May 11, 2010
    When tape ejects "eject - R" is displayed on screen. Have never seen this before.
Try better quality VHS tapes or 6-hour tapes instead of 8-hour ones. I had this problem myself when I used 8 hour tapes, but haven't had any problems with the 6-hour ones.
Posted on May 17, 2009
    Problem Solver:
  • 7 Answers
On vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Posted on Jan 02, 2009
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
TV/VCR combo unit trying to eject non-existent tape
The problem is that the loading is out of timing by a tooth. This would explain both the attempt to load a non-existant tape as well as the unit shutting down. This unit needs to be disassembled and the belts replaced and the loading mechanism re-timed. I have done many of these with success. While time consuming because the entire unit must be taken apart, it is not a real difficult repair for anyone that has done them in the past. Where are you located so I can make a referral?
Dan
Apr 09, 2009 | Philips Televison & Video
Sony SLV-272UC VCR player It shuts itself off in 2-5 seconds
Is there a VCR tape inside the unit? If there is a mechanical issue may cause your unit to auto protect and shut down.
Oct 01, 2008 | Televison & Video
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Jul 09, 2006 | Emerson EWD2203 DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
1,305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
