Question about Canon Pixma iP6000D InkJet Photo Printer
Waste tank replacement
Is it possible to replace or empty the waste tank on the Canon iP6000D? We're getting a warning that it is about full.
  • Anonymous Apr 20, 2009
    My Canon Pixma iP6000D InkJet Photo Printer says the "waste ink absorber is full". How do I reset this function or fix this issue?
    Genius:
  • 2,985 Answers
Possybly- go to www.fixyourownprinter,com
Posted on May 09, 2007
Replace the waste ink absorber on my Canon Pixma ip6000D printer
Seems to me that deposit of wasted ink is full. Try w/ a Quill tip o fabric clean excess of ink in the waste compartment (gently). Also cean the brushes.
Oct 23, 2012 | Canon Pixma iP6000D InkJet Photo Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
WASTE INK ABSORBER FOR CANON
Hi there this not for your but it may do worth a try
I enter service menu like this:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
Feb 19, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
"The waste ink absorber is almost full." message on my computer
no it is the function of software some of wast ink is over the absorber pad reset your printer any canon service centre. first time off printer press resume button and then printer on wait three second then relaise this button
Jun 27, 2009 | Canon Pixma iP6000D InkJet Photo Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Waste toner tank
A few things can cause this.
The way the printer determines whether the waste tank is full is via 2 optical sensors, one on either side of the tank. You'll see a rounded bulge on one end of the tank - the sensors are on either side of that, when the tank is installed. Under normal operation, light passes through that and the printer reads it as meaning the tank is not full, until the tank fills far enough to fill that bulge, and thus block light and give a tank full reading.
If the tank gets too dirty, not enough light passes through and it gives false tank full readings. So the first thing to try is cleaning the tank with soap and water. Make sure that area is as clear as possible.
If that doesn't work, it has also been reported that the sensors themselves are unreliable. I am told Samsung will replace the sensor for free if it's been less than 3 years. If you call them, insist that it is the sensor that is the problem, or they will try to get you to replace the waste bin, at your expense, first: 1-800-726-7864.
Alternatively, you can remove the sensor from one side, and reattach it to the other side - putting the two sensors in contact so that they always read an empty waste tank. Do this at your own risk, however, as you will have to check the tank regularly and make sure it doesn't overflow. Doing this bypasses the sensor, so there is no longer any warning if your tank is overflowing.
Hope some of that helps you.
-Dyllan
Jan 14, 2008 | Samsung CLP-510N Laser Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
201 people viewed this question
old marine
old marine
