When my computer stands idle i loose my connection to my router i then have to reset my router by unplugging it, please help me fix it
D-link 1310
Posted on Jan 01, 2009
Blinking lights
when the router looses connection, it is best to just leave it as it tries to reconnect automatically
the blinking lights is the communication process and when connection is made for each section the light stays full on
there should be a on/off button that you just press to restart the searching process or a reset button under a small hole that you use a paper clip to gently press to reset
remember that it is not always the router that looses the connection but the server that it is connecting to
Jul 10, 2017 | Cisco -Valet Wireless Router
My router stopped giving wi-fi to my computer. What can i do?
you can try reseting your wireless network.
It is a soft reset so you will not loose your configuration.
Unplug power on your modem and on your router.
Wait 20 seconds then put power back to the MODEM FIRST.
Wait 30 seconds and then plug power back in your router. Wait 20 seconds again and try your connection.
If not, try restarting your computer after doing the steps.
Hope this helps!
Feb 21, 2011 | D-Link DIR-625 (790069292637) Wireless...
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am...
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Jan 01, 2011 | Linksys RangePlus WRT100 Wireless Router
Can connect computer to internet through modem but not modem-router-computer. Everything worked fine until I accidently unplugged and reset the router the other day. My computer can connect to my wireless...
Use the reset button on the back panel of the router. You will need a pen or toothpick to press the reset button. Once you reset the router, then configure the router as if new.
Dec 10, 2009 | Linksys Wireless-G WRT54G Router
My wifi says limited or no connectivity. How can i fix it?
Straighten-out a paper-clip.
Push one end inside the pin-hole in the back of the router,
and hold for 2 seconds.
This will "reset" the router to "factory" settings.
Then, follow the instructions that came with the router
to do the "first-time" setup of the router.
Sep 10, 2009 | Dell Latitude C610 Notebook
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Wireless problems
Here in Denmark, lots of people are well tired of this router.
It often loose internet connection, but a hard-reset fix the problem most times.
Maybe you just have to unplug the power for a few seconds and then plug it back in, - wait for a minute or two until all the lights are on.
If this doesn’t work, please respond, and well find another solution.
/Teis
Dec 01, 2008 | NetGear WGR614 Router
Usr8054 router losses connection
What you can do to this problem is reflash the firmware of this router, then you need to reset the router by pressing the reset button for 15 seconds and after that reconfigure the settimgs of the router and observe if you still have the problem , hopefully that will fix the issue of your router...
Oct 19, 2008 | U.S. Robotics (USR8054) Router
DI 514 Wireless Router Problem
Okvassiw - Don't rate this til it's fixed please. Can I assume you reset the configuration on your router from defaults to your settings? First , unplug your modem and your router. Leave unplugged for a minute. Then plug in the modem. After 30 seconds plug in the router. Give it 15 seconds and try it. Let me know what happens and I'll tell you how to proceed. Thanks.
Jeff
May 15, 2008 | Computers & Internet
Problems with second computer connecting to the internet
First, is your kids computer trying to connect via the WiFi connection? If so, do you have any encryption enabled on the Belkin? (WEP, WAP, etc.) Can the computer 'see' the WiFi Access Point, meaning can it see the SSID (or WiFi name)? Are you using the Built-in XP Zero Wifi Config Utility, or did you install a proprietary utility from Belkin?
Since you have already soft reset the router (power cycle), you may have to do a hard reset using the Reset Button on the back of the router.. you will loose all your configurations, so be ready to setup your WiFi connection again..
Dec 19, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
