Question about Spark Plugs BR4HS Plug 10/BX #3322
How to change the spark plugs on a 2002 nissan pathfinder le
Change spark plugs
1990 Nissan Pathfinder 4wd starts and runs fine but it will not go into gear to drive or reverse,what is the problem?
How To put a Nissan Into 4 Wheel Drive - YouTube
? 2:09
https://www.youtube.com/watch?v=IirIxH0WIVI
Mar 13, 2011 - Uploaded by suzuki230
Just a quick How To, on putting your Nissan into 4 wheel drive. ... to warn the newbies not to drive on hard surface while in 4WDthis can ... If you're having difficulty engaging the 4wd low gear, you can steer ... Hey man i have a 1991 nissan pathfinder SE im going to install a ... How fast can you go on 4L?.
Nissan Pathfinder Questions - automatic will not go into any ...
www.cargurus.com > Questions > Nissan > Pathfinder
CarGurusautomatic will not go into any gear - was driving and parked. now it wonit go into gear. ... Asked by avips Apr 14, 2010 at 04:02 PM about the 1993 Nissan Pathfinder. Question type: Maintenance & Repair ... 2002 Nissan Pathfinder LE 4WD.
Automatic Transmission May Not Shift Correctly at High ...
repairpal.com > Problems > Toyota > 4Runner
truck periodically will not shift into drive at initial start-up. Will very often shift ... 1990Toyota 4Runner- Automatic Transmission100,000Visitor. I have very similar ...
10 Most Common Transmission Problems
Jan 01, 2016 | Nissan Cars & Trucks
I scanned my 2002 pathfinder & it say random misfire I checked every coil & there good I think but I can hear it arching is it my valve timing control solenoid power supply circuit # 2
Try putting silicone spark plug dielectric grease in the spark plug boots after pulling them off and cleaning them. It could also be bad wires. Try running at night in the dark, then you can see sparks if the wires are leaking.
Aug 28, 2014 | 2002 Nissan Pathfinder
Sounds like my 2002 nissan pathfinder is bogging down when i gas it , it runs fine but gets crappy gas miledge
needs a tuneup, definately change fuel & air filters, replace spark plugs & wires, distributor cap / rotor, change oil & filter, it would'nt hurt to replace cat conv., it restricts exhaust flow, between you & me , take it off, put a straight pipe in its place, is your inspection up to date ? you'll have a year to replace your CAT, before next inspection. just remember that. nissans this year usually need to have the timing belt replaced, nissan charges $900 + to do it. BIG DIFFERANCE ! see how it runs after tuneup, also , you may end up replacing both the cam & crank sensors down the road. I would replace the OXYGEN sensor/s as part of tuneup, it will help a great deal.
Mar 05, 2013 | 2002 Nissan Pathfinder
Meaning of code p0301 and p0300
they mean your cylinders have been miss firing which you can fix by replacing spark plugs and spark plug wires
Jan 23, 2013 | 2005 Nissan Pathfinder LE
98 nissan pathfinder 3.0 wont start new distribitor no fire
What do you mean "the battery still no fire"?
Do you mean that there is no spark at the spark plug?
Have you pulled out a plug, grounded it and cranked the engine to check to see what colour (if any) the spark is?
If there is no spark at the plug, then either change the plugs if they look to be in very poor condition, or change the coil.
Nov 13, 2012 | 1998 Nissan Pathfinder
How do I change the sparks plug for my 2000 Pathfinder?
Remove the air duct on the engine and Disconnect the harness and brackets around the ignition coil and remove the ignition coil. Unscrew and remove the spark plug and replace it with new spark plug in to the cylinder well and tighten it. Make sure to adjust the tension of spark plug as per the specification of spark plug manufacturer. You can find all Nissan Pathfinder parts at http://www.carpartswarehouse.com/carmodels/CP10/Nissan/Pathfinder.html
Aug 11, 2011 | 2000 Nissan Pathfinder
Have 2002 Pathfinder would not start.
alot of times you will loose spark because of your crank/cam sensor malfunctioning this will cause a lost signal and keep the spark from igniting. you can ohm check the coil to see if that is where you are loosing spark also. other than that it could be your ignitor but those are the most common malfunctions let me know what you find out, good luck
Erik
Dec 11, 2008 | 2002 Nissan Pathfinder
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
709 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
ken skalski
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
