Question about Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IDL530 Dishwasher Leaking
I have had my IDL530 for one year, never had a problem with it until recently - when it has been loaded and switched on, it starts to leak from the bottom right hand side around half way through the cycle - is there something I can do to fix the problem or do I need to call an Engineer?
  • Ade01 Jan 02, 2009
    My dishwasher is also leaking from the back right hand side of the machine. It seems to be coming from the drain hose.
    Can anyone tell me how to dismantle the dishwasher to get access to the inside where the hose connects , as this is where the problem is occuring.
  • 3 Answers
I fixed it myself in the end, the drain hose had a split in it and needed replacing. The problem I had was getting to the drain hose, as it is attached internally to the pump in the bottom of the dishwasher.
Here`s how to get to it:
First, remove the two screws from the back of the dishwasher on the bottom plate, there should be one on the far left and one on the far right.
Put a towel on the floor to soak up any excess water and tip the machine onto its back, so the door is pointing upwards.
At the bottom of the dishwasher you will see two more screws holding the plate on.
Remove these and carefully detach the plate.
You will notice a microswitch on the inside of the plate that has an orange and white wire connected to it.
Make a note of which way round the wires go, as the connector can be put on either way. Remove the connector from the micro switch and then completely remove the plate.
You will see the drain hose attached to the pump with a brass butterfly clip. You will need pliers to open the clip and slide it off the hose where it connects to the pump.
Once you have done this, you need to remove the white plastic clip that goes round the drain hose at the point where it exits the washer.
This clip slides up and away from yourself ( when facing the dishwasher on its back ), then it splits open and comes off.
This should allow you to remove the drain pipe.
Once that is off , its a simple case of getting a replacement pipe and fitting it. ( Follow instructions in reverse )
A word of warning though - I hunted high and low for a replacement and ended up ordering the wrong one from Partmaster.
The pipe MUST have a 90 degree bend in one end, if you search partmaster for Indesit IDL500 drain hose you will see one for £7.99.
You must get this one, as I made the mistake of ordering what I thought was a cheaper alternative ( £4.99 ), The cheaper one also had the 90 degree bend, BUT the end was too small.
Compare the images of the two and you will see that the more expensive one has a larger end at the 90 degree section.
Hope this helps.
Posted on Jan 09, 2009
I had water coming from both the bottom right and left hand side of the door and couldnt figure out what it was, so called a local engineer who scratched his head for 30 minutes charged me a fiver and didn't fix the problem.
Called Indesit, who charged 90 quid for one of their engineersto come and cut 1 inch from the bottom of the door seal on each side, which fixed the problem. The moral is don't call the Indesit engineer when this is a problem that they are aware of as they will still charge you 90 quid callout fee for a five minute job.
Posted on Jan 08, 2009
  • 126 Answers
If the water is coming from the door you may have an issue of oversudsing Place a cup of vinegar upright in the dishwasher and run it through a cycle this will cut any residue build up. You may need to repeat this. put a towel on the floor just in case . Check that the door gasket is fully attatched and undamaged. If the water is coming from under the dishwasher it could be one of several problems from a bad connection to bad valve to a loose or broken hose to a problem with the pump. you should probably schedule service before the small leak causes bigger problems.
Posted on Jan 01, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Lg2277hw - sometimes the start button works very easy on the 1st gentle push- other times I have to repeatedly push the start button - eventually it starts - sometimes it starts but then I get the de
If the door switch contacts have burnt out then the switch will never work and neither will the machine until the switch is replaced. If the door switch button is worn then it will need replacing. If when you switch the machine on and it does not start, try giving the door a "shove" or "gentle thump" in the door latch area. if the machine then starts it will no doubt need a new door switch. if it does not start then the main ON/OFF button or the door switch will need to be checked. Both these components take the full power of the machine as long as the machine is running so they are prone go faulty. Unless you are comptent with electronic components I can not explain how to do this for safety reasons.
Apr 14, 2012 | LG WM-2277HW Front Load Washer
Why does the door in my indesit dishwasher not open during the cycle.
If a europeon model for the europeon market then it may not open depending on year of manufacturer which is due to europeon safety measures introduced recently by the europeon parliament commision
Oct 10, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
My indesit IDL40 slimline dishwasher keeps leaking?
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 25, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
I have a ztr mower that drove fine until recent oil change
Did you purge the hydro system after the service/repair? At the shop we always jack the rear of the mower up,start it and engage the drive levers and let it sit for 15-20 minutes to get the air out of the pump,wheelmotors and lines.
May 17, 2010 | Garden
Indesit 18" d41 dishwasher leaking from bottom of door area
Leaking Dishwasher
heatman101
,.gf.lo
Jan 23, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit 24 in. IDL500 Built-In Dishwasher Logo
1,975 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
