Mouse pointer freezing in xp
Acer extensa E210. Came with Vista Home and only 512Mb Ram. Had problems with mouse pointer freezing - sometimes after a long delay mouse pointer would free up other times had to pull the plug. Tried formatting and installing xp - still doing same.Any ideas - thinking of replacing RAM but dont want to waste money.ThanksSteve
  • BobRobert1 Mar 18, 2009
    I recently installed a Logitech Web Cam on my computer.Ever since I have a problem with the mouse.It won't move after a short period of time.The only way I can get it to move is shut the computer off and tun it back on after about 15 seconds.I talked with Logitech and they suggested moving to another port.I haven't tried this yet,due to just having hip replacement surgery.Any help would be appreciated.
    Bob
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Try another mouse
Posted on Jan 02, 2009
Acer Extensa E210 totally death
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Acer Computers & Internet
I have a Medion wireless mouse and the mouse pointer keeps freezing intermittently. The operating system is windows vista home premium.
Make sure the mouse batteries are fully charged.
Also make sure the mouse is not too far away from the base / cradle and there is nothing blocking the sensor on the front of the mouse cradle.
Make sure all the cables are fully inserted. Check both ends of the power adapter plug going into the back of the mouse cradle and the plugs leading to the back of the computer.
Try cleaning the little red LED light under the mouse with a QTip to remove any dust.
Finally try using a different mouse pad. Some work better than others with certain brands of wireless mice.
Also make sure there is not another wireless mouse being used in close proximity. The two can often interfere with each other.
Good luck and please comment back and RATE if this was helpful.
Feb 05, 2011 | Acer Aspire M3201 Phenom X3 8650 PC...
No memory
OS Vista minimum want 512 mb ram for run. & yiur only 512 mb ram which is used for your all program. So incres your ram Atleast
1 GB. 2 GB is best.
Jan 30, 2010 | Acer 4220-2346 Notebook
Mouse continually skips around. I changed batteries, reset it and everything. What's wrong?
You have the tracking speed set too high.Go to 'start'-'control panel'-'printers and other hardware'-'mouse'.After opening mouse you'll see "pointer options",click and you'll see "pointer speed".Move the speed down from fast to slow until you can see it easily.The other thing is if you don't have enough RAM memory it won't be able to keep up with simple hand movements.Click "start'-right click"computer"left click"properties"and up will come what you have for a computer will be displayed.Near the bottom of the page will be RAM,to it's left is how much you have.XP you need at least 512MB(1GB is better-up to 3GB best)Vista 1GB minimum,up to 6GB with Vista x64.Adding Ram is the easiest way to speed up a sluggish machine.Please re post if you'd like to get into changing setting for best performance.
Dec 30, 2009 | Dynex Wireless Optical Laptop Mouse...
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Stuttering Graphics
check for the mouse pointer movement speed.... this can be located in control panel --> Mouse Options.... there check for the mouse wheel speed and decrease it ..this may help.... sometimes wireless devices doesnt have compatibilty will vista OS , this may also cause an issue..if any vista drivers exist for ur mouse install them and check ...hope this helps...
Aug 18, 2009 | Computers & Internet
Asus eeepc 701 with xp mouse pointer stops working intermitently
It probably just freezes due to too many tasks. After all that laptop doesn't have a lot of RAM, it's a great device though, i have the same one.
Feb 24, 2009 | ASUS Eee 4G Notebook
Mouse Pointer freezing on Vista Intermittently
try to install the service packs and updates. You might want to save the downloaded files while you're at it. In case it works you need those for the other 2 machines. hope it helps
Sep 25, 2008 | Microsoft Windows Vista Ultimate Edition
Logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Internet & mouse
check the BIOS if the USB support is enabled. check also on pointing or pad device that is also enabled.
Jan 23, 2008 | Acer Aspire 5610-4648 Notebook
Open Questions:
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
