Question about Refrigerators
Ice machine not dispencing ice - Refrigerators
  • jhpabenne Jan 09, 2009
    I have a Maytag ref. model#MSD2456DE.
    The ice machine is not making ice. The freezers temp is 2 degrees, the ref. is 38 degrees. The evaporator fan is working fine and the evaporator coil isn't freezing up.
    I vaccumed the bottom of the ref. so the air flow is good.
    The ice machine is making a clicking sound for some reason.
    What test can I run to make sure if the ice machine is faulty and not something else? I don't want to spend $140 on an ice machine and find out it is something else like its not getting water to the ice machine (How do you test for this?) I Thank You in advance for any help and suggestions you can give me.
    Sincerely,
    John
  • skiwagon2 May 13, 2009
    Ice maker is inop. everything else is fine.
    Any suggestions for troubleshooting?
    Thanks
  • Refrigerators Master
  • 8,220 Answers
Bad ice mold thermostat
Posted on Jan 02, 2009
ICE DISPENCER WILL NOT WORK
Either your machine water valve or ice maker unit is at faulty. In some models it can be the Ice level sensor unit. Also Ice maker will work only when the freezer is below a certain temperature. It is around - 11 C or lower.
Oct 07, 2014 | Whirlpool Refrigerators
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice dispencer working water dispencer not working
If the machine is getting ice - the micro-switch for the selector, or an onboard relay has failed.
If the ice maker is NOT getting ice - look for the dual inlet water valve to be at fault.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Neff K3965XO Side by Side Refrigerator
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
