Question about Saeco Incanto Classic Espresso Machine
I just purchased the machine and is stack on ventilation mode,try several times,pump seem to working but no water comes out of the nozle.....
Posted on Jan 13, 2009
How do I make ventilate message go away
  • Check to make sure there's nothing inside your flow meter.
  • Check the flow meter wire connection at the board (cpu/pcb).
Jun 22, 2015 | Saeco INCANTO DELUXE Espresso Machine
We are getting a "ventilate"
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Mar 03, 2011 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website:
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit
May 29, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
221 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
