Question about Radio Shack Pro-2096 Base Scanner
Programming will not stay in scanner
I programmed my scanner a few days ago and have been on vacation. I turned it on today and all the banks are empty with no frequencies that I previously entered. I keep it plugged in when it is turned off. This continues to be a reoccuring problem. Do you have any suggestions?
    President:
  • 2,976 Answers
Take the batteries out. There should be a small door covering a few button cells. These keep power to what retains your settings. If they are dead, as soon as you unplug the unit, it will go blank.
Posted on Jan 01, 2009
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
BC72XLT scanner does not stop on some programmed channels while scanning. My other scanner will read the transmission. The numbers indicating banks 1 and 3 aare not visable during scan, are they locked...
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
Apr 01, 2011 | Uniden BC72XLT Handheld Scanner
I have programmed my pro164 scanner using win97 software and the pc patch cable. i have frequencies programmed to channels onto bank 0. i also programmed the desired talkgroups onto bank 0. problem is when...
you will have to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ .
but if you have tried doing this.i advise do it again.again run the program by connecting the cable again.if you have not tried it then do it again. if still the same problem.then it might be the problem with the scanner.get it rechecked from radio shack. there are many many users facing this same problem this particular model of radioshack scanner and other model in which this same problem occurs is pro-197. get it checked with radio shack.tech. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 27, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
How do I program conventional frequencies into my Uniden BC898T? I have Motorola TypeII Digital Tunking frequencies programed into Bank A and EDAC Digital Trunking frequencies programed into Bank B
Just go to Bank C or anything after that and start entering -- one channel, one frequency. It's kind of cumbersome to do by pushing the keys, but it works. An alternative is to use the BuTel software. It will simplify programming and give you Virtual Control of the scanner through your computer.
If this helps, please give us a rating. A "very helpful" would be greatly appreciated.
Nov 22, 2009 | Uniden BC898T Base Scanner
Dyslexic handicapped needs help programming the RS Pro-96
Hello Jim
I will try my best to help you. Go to manual and push till you go to the number you wish to use, If the numbers on it or all 00000000 you can put what frequency # on it. as long as it is all 0000000 you don't have a thing on that # to interfere with. When you get the # you wish to use put the number in, if your # has a . in it you will need to put the. in hit enter then prg. ik.ditterline@yahoo.com
Mar 30, 2008 | Radio Shack Pro-2096 Base Scanner
Scanner not working
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Feb 08, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-2096 Base Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
