Question about Brother XR-65t Mechanical Sewing Machine
My machine is ceasing up on me.
My machine has been squeaking a little. I oiled all the right places and began to work again. Out of the blue the machine completely stopped. I turned the hand wheel and nothing happened. It won't move. It has been a great machine for me up until today. Can you help? Thank you! AmySue Crawford
  • 37 Answers
Check and make sure there are no threads in the bobbin casing and shuttle area. It might be binding up down in there.
Posted on Apr 15, 2009
A squeaking noise just started. Does this machine need oiling?
Yes On Any Sewing Machine You Should oil It.! When it come's brand new in the box it normally comes with a little bottle of oil it is a must to oil the treader Etc.
Jul 31, 2017 | Sewing Machines
My new Juki 2200 QVP is squeaking while I'm quilting with the walking foot. I have oiled all of the places indicated in the book. I've only got about 10 hours on this machine. Any suggestions?
Is it the walking foot that is squeaking? No one mentions that the moving metal parts need a touch of oil to keep the walking foot working. Just be sure to clean off any excess before using on your fabric.
Mar 30, 2017 | Juki Sewing Machines
Have a Kenmore 1357. Was working perfectly until I began sewing satin ruffle onto fleece. Seems to siege. Needle won't even try to go into material. Just goes to top of presser foot and stops.
Is it a mechanical machine (not computerized)? Did you oil the internal metal parts that rub against other metal parts? With an older mechanical machine, frequently the old oil turns to goo and sticks things rather than lubricates. Use only fresh good quality sewing machine oil. Hand rotate the wheel and place 2 drops of oil every place metal rubs metal (including the bobbin area). To help loosen things, direct hot air from a handheld hairdryer into the interior of the machine.
This process was used on an older Kenmore that had totally frozen, but it was working again within 15 minutes.
Dec 11, 2015 | Kenmore Sewing Machines
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Machine squeaks when sewing
Is it a mechanical machine (NOT computerized)?
Do this ONLY if it is MECHANICAL. Remove the top lid and the freearm cover (if no free arm, then you'll have to tilt the machine so you can access the lower mechanism).
Use ONLY fresh good quality sewing machine oil. While handrotating the handwheel, watch where metal parts move against other metal parts and apply 1-2 drops of oil. Do NOT oil plastic, rubber, or leather parts as oil will eventually destroy them.
Be sure to oil the moving parts in the lower mechanism as well. Hopefully this will take care of the squeak and get your machine operating 100% again.
Oct 23, 2015 | Sewing Machines
How can I get my PfAFF1221 out of REVERSE?
If your 1221 is like my 1222a, the reverse lever is right on the front, just above and to the right of the needle stack. Vertical is "stop", left is reverse, and right is forward.
Sep 12, 2014 | Sewing Machines
I've borrowed a Silver 302 from my neighbour, and after a few hours use, it's started squeaking. Loudly. I don't know if this model needs oiling or not, and if not, what it may need doing to it - just...
I'm not familar with this machine but will make some general suggestions. I did google it and found a 502 http://www.silverviscount.co.uk/shop/product_info.php?cPath=21&products_id=40 it looks like a economy front loading bobbin machine.
If you manually turn the fly wheel to form the stitiches and listen carefully can you hear a popping as the needle enters the fabric? If yes, its a needle problem. All machines need a new needle for each sewing project, 4-6 hours sewing time, before they go blunt. Cchange the needle for a new one in the right size for what you are sewing (ballpoint for knits, sharp for wovens). Refer to www.sewing.about.com for good general info on machine maintenance, needle sizes and types and threading diagrams, its a wealth of information.
If its not a needle issue then I would suggest that you open up the front flap, remove the bobbin holder, needle and pressure foot and clean out the race area with a small brush, then again manually turn the fly wheel and add a little drop of good quality machine oil to anywhere where you can see metal moving against metal and see if this quietens down the squeaking. Don't use 3-in-1 oil.
You could also ask the neighbour for the manual and check out if it does have oiling points to try and eliminate this as a cause.
Hope this helps a little.
Mar 08, 2011 | Sewing Machines
The handwheel is extremely hard to turn. it will turn using the foot pedal but it makes a whining noise. could it be the belt?
Look on the back of the machine there is usually a tension dial. Try adjusting that. I f that does't work your manual lists instructions for cleaning and oiling a little bit of oil in the right place works wonders or on the oher hand a little thread in the wrong place will stop an electric motor.
Feb 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
Mar 01, 2009 | Kenmore 15208 Mechanical Sewing Machine
Bernina 830
Pop the top open. (push up on each end with thumbs). With the top off and you watch the mechanism as you move the stitch selector up and down you will notice this moves between a forked shaped part on the right side in back that is supposed to click in place back and forth. Its very common for this to be gummed
up. Oil it and keep moving it back and forth and oil it again. It will
start clicking in and you will be in business.
Jan 03, 2009 | Sewing Machines
Brother XR-65t Mechanical Sewing Machine Logo
140 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
