Question about PC Chips M963GV (V3.3A) Motherboard
No vedio On board is shot. been working with pci card but a wire hit the side of the card it sparked now no vedio.Both pci slots dont work.The card is still good for sure.It did something to the board.It still starts.Can I get a AGP card & try that?Something happen to the 2 pci slots or to the board because it was working just fine.
    Scholar:
  • 99 Answers
If a wire touched the side of the video card and there was a spark then that wire shorted something out. The video card is likely bad now and it is also possible that there was damage to the motherboard. If the motherboard still work then a working PCI video card or AGP video card would work. If there is damage to the motherboard from the short then it is possible that the PCI slots as well as the AGP slot will not work but there is no way to tell if that is the case without testing the electronics on the motherboard or plugging in a working video card to see if it works.
Posted on Jan 04, 2009
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
I want to replace vedio card 128k to 512k my motherboard is asus p5gl-mx is it available?
Any PCIE video card will work in the slot provided, although some larger cooled ones may stop you using pci slot 1.
Jul 25, 2011 | ASUS P5GL-MX Motherboard
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
Want to upgrade the video card but dont know where to start. are the three expansion slots at the bottom of the board used to expand drivers like the video?
Hi there.
Seeing as the graphics on that board are integrated Intel Extreme Graphics and the board does not have PCI Express or AGP slots then you can use one of the 3 PCI expansion slots to install a video card.
The largest PCI graphics card I've seen is a 512MB card and that was not cheap as the latest video slots are PCI Express.
It will however free up essential system memory which is always a good thing.
Regards
Jun 11, 2009 | Intel D845GVSR Motherboard
Nvidia graphics card won't fit in asus ncch-dl motherboard
The NCCH-DL has the following slots:
1 - AGP-Pro 8x
(you can use regular AGP cards in here as well as long as you have the little plastic thing that comes with the mobo... you may even be able to without it)
2 - PCI-X
This is NOT PCI-E.
You CAN use regular PCI cards in a PCI-X slot IF the company that manufactured the card left the space between the little metal contacts... unfortunately, many PCI cards are made with the space filled in with useless plastic... I've heard you can cut the little space yourself and it'll work fine... I don't know why it wouldn't but be careful, and of course do at your own risk.
I currently use a regular PCI network card in this slot because the onboard LAN port only has Win64 bit drivers on the web site and it works just fine.
A PCI-E card will NOT work in this slot.
Generally speaking the PCI-X cards you are going to find are riser cards, network cards, firewire cards, and controler cards.
2 - Regular PCI Slots.
I think you know what PCI is.
May 03, 2009 | ASUS NCCH-DL Dual...
HP Pavilion 760 pci device
hi, when you see the yellow of PCI devices this means you have to check all the cards that connect to your board as PCI, so this could be sound card, vedio card, modem or any pci card, just double check with your pci cards, so if you have pci sound or vedio see if the driver there if not will be one of them, But many times people doesnot recognize that they have extra pci card which could be for usb use, or output devices, etc...
Mar 01, 2009 | HP Pavilion 760n (P6320A) PC Desktop
NO Video
Hi bigguy1967, the motherboard does have an 8x AGP slot.
Universal AGP v3.5 Compliant and Support 1.5V AGP Interface Only. Here is a link to a couple AGP 8x cards.
This is 1.5v compliant:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1892411&CatId=318
& this is too:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4297004&CatId=318
Good luck bigguy1967!
Mike
Jan 02, 2009 | PC Chips M963GV (V3.3A) Motherboard
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Dec 30, 2008 | ASUS PCI Express Graphic Card
Vedio controller
Your AGP (Advanced Graphics Port) slot is a Video Card Slot on *********** Board... It is usually a brown slot this is above the PCI (white slots). You have to have a Video Adapter ( video card ) for your PC to display ANYTHING, so you either have a card or you have onboard video which shared some of your system RAM for Video. This card is where you plug in your monitor, so if your monitor plugs into a seperate card then you probably have an AGP card, if it plugs in near the mouse/kb/sound then it is most likely an onboard video adapter.
Dec 18, 2008 | Computers & Internet
PC Chips M963GV (V3.3A) Motherboard Logo
65 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
