Question about DFI NF4 ULTRA INFINITY Motherboard
DFI nF4 Infinity problem!!! plz help
Hi! I have a computer based on nvidia NF4 ultra infinity chipset. Two days ago I have noticed that the screen was frozen and it seems like the computer in halting. tried using keyboard to get it to work again but no success, so i have rebooted the computer with the power button (pressed it until it closed and then reopened it) it worked But after a couple of seconds it froze again so I turnned the computer off. Yesterday the computer failed to turn on when i tried to do so the screen didnt get any signal and there is a green led light that is blinking above the power button (telling me something is wrong for sure), so I started with a serious of acts to see where the problem comes from - but with no success. here are the things i have tried: 1. chacking graphics card - trying to put a different one restarting the computer with a new and without. 2 checking DDR - both ddr and each one alone to check if one of them or both of them is having a mailfunction. (usually when the problem has to do anything with memory the computer gives small sound beeps - this time it hasnt) 3. tried to dissconnect the DVDrom and some hard-drives - thought it might be a power supply problem. windows xp, amd athlon 64 x2 4.2 processor. please help... thx
  • Bobbi Lindam May 10, 2007
    hey guys...
    took the motherboard for a checkup.. it seems like it just ruined .. dunno why or what is the cause but i can say i'll check it with electricity since of power cuts lately..
    Problem Solver:
  • 19 Answers
Disconect the power connector that goes to the mother board add by-pass a wire from pin 15 and pin 14 and see if power goes on on drives
Posted on May 09, 2007
  • Helder Luis
    Helder Luis May 09, 2007
    see if you have
    +3.3V
    +5V
    +12V
    -5V
    -12V
  • 779 Answers
Are the fans running - sounds like a PSU problem to me do you have a mutlimeter you can measure the voltage from the PSU - the motherboard website should have a manual, with pinouts and voltages.
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Posted on Jun 28, 2008
  • 59 Answers
SOURCE: DFI NF4 INFINITY MOTHERBOARD NON BOOT
Could be the Hard drive or memory. Sounds as though it is reaching post. But dies after that, I would check both. I have seen both be the problem on other systems.
Posted on Feb 25, 2009
  • 4 Answers
SOURCE: dfi nF4 DAGF red in light flashingon MOBO.. Fans
the cpu power probably isn't plugged into the mobo. It's the 4 pin spuare pwr connector
Posted on Jan 05, 2010
Manual for LPUTNF4SLIDREXPERT
please help me find an online manual for this motherboard please mate hi brian i was wondering if u cud help me find an online manual for this motherboard (DFI LANPARTY UT nF4 Ultra-D) as im selling it on and want to check all the jumpers are in the correct positions please help me out dude, many thanks in advance for any help matey
Mar 27, 2013 | DFI LANPARTY UT nF4 SLI-DR Expert...
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
I want driver for this motherboard
Here are the links for the DFI NF4 driver you have requested.
Jan 26, 2011 | DFI NF4 ULTRA INFINITY Motherboard
Where can I find the drivers for Windows 7 ?" DFI NFII Ultra"
Hello my friend,is very old motherboard and i couldn't find and i don't think that there are drivers for windows 7.The only think you could do is to try this motherboards XP drivers or better your motherboard`s windows XP sound drivers.
Feb 05, 2010 | DFI NFII Ultra INFINITY Motherboard
DFI infinity wont post
Hi...
When your computer continuos beeping the problem is the RAM you need to open the CPU casing and check the remove the RAM clean the dust then after that, reinsert the RAM to the socket, then turn on your computer. "good luck".
Regards
PCmania
Jul 13, 2009 | DFI NF4 INFINITY Motherboard
sounds like a hardware problem. try unplugging all external devices including keyboard and mouse but not monitor. test if it works. if not, open the side of the case and remove the little battery found on the flat motherboard for 30 seconds. then slide it back into place. now try to see if it works. if still nothing, check to see if there are motherboard jumpers (they will be 2 tiny pins on the board with a clamp over the top of them, you probably wont find them), if you see the jumpers, move the clamp to the spot that says "clear cmos" then put it back. or if your motherboard has a clear cmos button on the board, press it and try the computer. if it still will not boot, it could either be the flat IDE cable (for a hard drive or cd drive) or the power supply which means you will need to purchase either a new power supply or ide cable. if all still fails, i would say the motherboard is shot.
Feb 25, 2009 | DFI NF4 INFINITY Motherboard
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
Board stopped working
try one by one first the graphic card then with powersupply
Apr 21, 2008 | DFI NF4 INFINITY Motherboard
DFI NF4 ULTRA INFINITY Motherboard Logo
350 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
