Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Amana freezer - Ice has an odor. Sometimes has particles in ice
  • 700 Answers
You need to do two things first replace the water filter or if you don't have one ou need one then flush the water lines out by running thru @ three gallons of water after you change oput the filter. this should cure the problem. please don't forget to rate the solution if it solves the problem. Thanks for using FIxYa
Posted on Jan 01, 2009
There is and odor that permeates the ice, freezer, and fridge. It makes the ice taste funny.
This could be because of other stuff in the fridge. Meat usually gives a weird odor and taste when its in the fridge with something else.
Mar 26, 2016 | Refrigerators
Ice maker freezing up, odor in freezer
is water supply ok? leak around freezer door, fix/replace freezer door gasket
Oct 09, 2015 | Frost Refrigerators
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
60 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
