Question about Sony BDP-S350 Blu-Ray Player
When going through the setup for our new blu-ray 350, I selected 1080p for the video output resolution but the screen when blank. I found out later there were instruction to reset from that point, but I had already turned it off, etc. How do I do a 'hard reset' to return it to the 'auto' setting?
  • 10,594 Answers
Press STOP key on player for more then 10 seconds. This will reset video out selection. Good luck.
Posted on Jan 01, 2009
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony Televison & Video
I have a sony bdps360 i need to reset the res from 1080p to 1080i i need HELP
You can select the “HDMI Resolution” of the Blu-ray Player is set to “Auto,” “1080i,” or “1080p” in the “Video Settings” setup. You can refer the page # 43 of the Manual of the Blu-ray Player.
Jan 16, 2010 | Sony BDP-S360 DVD Player
Hooking up ps3
To get 1080i (the 50V will not do 1080P) from the Blu ray player you do have to use HDMI output on the PS3 to the DVI input.
I found one at Walmart. Phillips makes an HDMI to DVI plug also at Wmart.
The PS3 must be set for the output you want on your TV.
Look in your manual in the PS3 box or go to http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The web site has much more detailed instructions, but the basic answer to your question is below.
  • The cable required to output a particular video mode may not be included with the product and additional purchases may be necessary. For details, refer to the documentation supplied with your system.
  • If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
  • Copyright-protected Blu-ray video discs can only output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP standard.
  • Hope that helps!
    Merry Christmas and Happy Holidays to you and your family.
    Dec 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
    No Display
    If your resolution on your TV isn't capable of 1080p it will not show anything on screen. You should set the Blu-ray player to max resolution of your tv.
    Hope this helps.
    May 27, 2009 | Sony BDP-S300 Blu-Ray Disc Player
    Screen resolution
    There is only one type of ''output'' which currently outputs 1080p and that is blu ray players.
    Sky HD, free sat HD and even HDDVD's only output at 1080i.
    Your TV will automatically output at its highest possible quality from the signal its receiving. Please re-clarify if you are using blu-ray, if not, go and buy a new Blu-ray player!
    Mar 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    How to reset the default value for the toshiba sd 6100 dvd player
    If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
    Jan 25, 2009 | Toshiba SD6100 DVD Player
    Games run on hdmi, but not Blu-ray movies
    You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
    Aug 08, 2007 | Sony Playstation 3 (PS3) Console
    Sony BDP-S350 Blu-Ray Player Logo
    469 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
