Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Kitchenaide Microwave KHMS145KSS rattling noise
This oven has worked fine for four years. REcently, whenever the oven is in use there is a rattling sound (sounds like a noisy fan). The oven works fine otherwise. Any ideas?
    Problem Solver:
  • 13 Answers
There is a possibility that sme of the wireing or the fan has become loose best checking it .
Posted on Jan 02, 2009
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
I have an GE Eterna Microwave Model Number: EMO3000HWW01 The microwave resets itself after aboout 10 seconds of use. Before it would do this and we would reset the time and date and it would work for...
It may be that the internal cooling fan is not working or the filters or air duct may be clogged, but it may also be a "noisy" magnetron.
First, check the filters. Then determine if the internal cooling fan is coming on.
I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If that is working, and you have good air flow, then see this FixYa solution.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Rattle sound
It's probably a loose stirrer fan or possibly a failing stirrer motor. Both are located above the plastic stirrer cover in the top of the cooking cavity.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 25, 2008 | GE JVM1850 1000 Watts Microwave Oven
Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Jan 15, 2008 | Neff B7740N0GB Microwave Oven
Weird rattling sounds
If it's less than a year old, it should be under warranty, and I wouldn't open it. I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
It may be a failing turntable motor, fan motor, but it really merits close inspection.
This is an inverter-based model, and due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
If you need your owner's manual, you can download it here:
http://service.us.panasonic.com/OPERMANPDF/NNH764.PDF
Dec 03, 2007 | Panasonic NN-H764 Microwave Oven
XL1800 still works fine but makes a lot of noise while on.
It may be the stirrer in the ceiling area.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
623 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
