Question about Refrigerators
Ice maker will not start, I have water coming out of the water disp, on front door but no water going to freeze
  • 700 Answers
First check to see if the water line is frozen in the freezer where it goes into the maker. use a hair drier to thaw it and then you should be ok. also how cold is the freezer most ice machines need around -2 to make good ice.
Posted on Jan 01, 2009
Ice maker stopped working water coming out of front of door. what to do?
There are two sides to a water control valve Cindy. One side for the dispenser and one side for the ice maker. Feel inside the ice maker slots for any remaining ice cubes. If the ice maker has no ice fill with tap water and if after the water freezes and drops the ice into the ice container and then does not refill with water the problem points to the dual water control valve. If the ice just sits in the ice maker and does nothing then this points to a defective ice maker. What is the model number of the refrigerator?
APPLIANCE 911
Dec 06, 2015 | Refrigerators
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
Ice maker no longer makes ice; water still comes for the filered water outlet but there appears to be no water going to the ice maker;
THE WATER VALVE IN THE BACK IS A TWO PART SYSTEM. EVEN THOUGH YOU GET WATER FROM THE DOOR THE ICE MAKER SIDE OF THE VALVE COULD BE BAD. CHANGE VALVE. B4 YOU SPEND THAT KINDA MONEY--DO A SELF CHECK FIRST--POUR WATER IN THE ICE CUBE TRAY. IF IT FREEZES AND DUMPS THEN CHANGE THEWATER VALVE. IF IT FREEZES BUT DONT DUMP CHANGE THE ICE MAKER.
Mar 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model E522B - Ice Maker not working - forced cycle does not flip tray. Water dispenser is working ok. Freeze r temperature set low.
freeze tempt even tho set low / how low is it / must be 0 to 5 deg too work well . it stops at 15 deg .. . make sure both fans are working and the cond coil is clean . .. very important . .. water disp does not work with ice maker . you have a dual valve in the back with two coils . the ice side may have gone bad . if so replace the valve . both sides / only way it comes . hope this helps **** ..
Jan 06, 2010 | Fisher and Paykel E522BRXU Fisher & Paykel...
Ice maker not working no water but the water in door disp.works
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
lkj;fds
Nov 02, 2009 | LG LMX25981ST Stainless Steel Bottom...
Hooked up water to frig and got water in door but no water to icemaker. Any ideas?
Make sure the lever is down on the ice maker . Also , can pour about 2/3 cup of water into ice maker , so it will freeze and start the cycle . Otherwise , wait , and when the ice maker gets cold enough , it will cycle on its on to start the ice making procedure . If you get water to the door , then it's connected properly , and water will go to the ice maker , if the water valve and ice maker are in working order .
Sep 09, 2009 | Kenmore Refrigerators
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
