Question about Toshiba TDP-T45U DLP Projector
Opening screen white not blue
When I turn on my projector I usually have a blue screen as it searches for the port the information is coming through.  When I turn it on now the screen is more white if i play a movie through the player the color is distorted and blurred.
  • 4 Answers
Most likely a bad color wheel toshiba part no. 23125963. You can find it online for about $65
Posted on Jun 24, 2009
Using a Dell projector, is there a way to get it to project white without any inputs, versus the standard blank blue screen? It goes white when searching for inputs, but switches back within seconds when...
Since you did not provide the make and model, you will have to pull out the manual and check the settings. It may provide you with a setting change for the background color. Perhaps you can connect it to a computer, open an new blank document and project the blank image to get your white light.
Mar 28, 2015 | Dell Office Equipment & Supplies
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
InFocus Projector-Searching
most likely it is your cable. If a for sure brand new cable doesn't fix it it is most likely the main board. Also try flashing the software again.
Apr 28, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Black and white stripes, no picture
just clean your projector board that connected to the main board, just clean the port.
Oct 08, 2009 | InFocus Play Big IN1 DLP Projector
Can't turn off the "searching" icon (on just the blue screen)
there may be a setting in the menu for auto-search to be turned on or off.
Sep 16, 2009 | BenQ PB6100 Multimedia Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Toshiba TDP-T45U DLP Projector Logo
197 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
