Question about Cornea MP 704 17" Flat Panel LCD Monitor
Monitor not powering up
I have an issue, the lcd is black but the monitor is powered on can anyone help?
  • Anonymous Feb 19, 2009
    Power light indicates signal received, but screen remains black.
    Problem Solver:
  • 5 Answers
Try another monitor on that same pc, try your monitor on another pc. Next, check the data cable for any short.
Posted on May 09, 2007
Samsung lcd le27s7 screening problem
The problem with your lcd monitor is that the picture board of your lcd monitor is faulty that is why it power on for one second goes gray and finally black with only sound.
Since the power led button is on and it still give sound but no display, it means the picture board of your monitor is bad.
All you need to do is to take the lcd monitor to any local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix all alone in other to complicate issue.
Take care
May 02, 2010 | Computers & Internet
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
Hannspree HF-289H LCD Monitor not displaying anything.
conor455, I am sorry to hear that your lc display has been struck down with the "BLACK screen of DEATH". Most likely the "switch-mode-power-supply/inverter supply" has failed!!! If your monitor is out of warranty then i suggest that you find your way to my fixya profile and read some of the responses I and others have already written about the BLACK screen symptom and what you can do to try and repair it!! YOUR DISPLAY IS SICK. The SMPS is in SHUTDOWN mode trying to save itself from further damage and or catastrophic nonrecoverable failure. eg. sparks, smoke, fire!! Leave your monitor OFF and do a little bit of research of BAD electrolytic filter capacitors and other stuff that causes LCD backlight's to fail to light-up. Conor, when you asked "ANYONE KNOW THE PROBLEM?" all I can say is visit YOUTUBE and search for and view some of the longer vid clips of "lcd monitor disassembly and/or lcd monitor repair to help YOU to make a decision as to the fate of your HF-289H. Bye for now. If this info has been of some use, please rate this response on fixya! 12fixlouie aka louie12fix
Nov 09, 2009 | Computers & Internet
HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Oct 25, 2009 | HP W22 LCD Monitor
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto http://www.ebay.com and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
Cornea MP 704 17" Flat Panel LCD Monitor Logo
120 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
