Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load washer will not agitate or spin.
I have a front load waher. My daughter put a small sock inside the detergent dispenser. This caused the dispenser to overflow. I removed the sock but now, the washer only fills and drains. It does not agitate or spin. Please help. Thanks, Jonathan
  • jnolan716 Jan 04, 2009
    Thank you very much for the advice. Unfortunately, it did not fix the problem. I think that it may be a bad motor control board. Thanks again.
    Jonathan
    Sergeant:
  • 311 Answers
Try this unplug unit for 5 min.while unplug remove soap dispenser and reach way back there and move the flaper from side to side.then retry.God bless,tom
Posted on Jan 01, 2009
Washer agitates but will not spin drain spin or fill
Well I have a Roper Top Load Washer, bought it in 1998 ,no problems til back 6 years ago we had someone come fix it. My problem was the same wouldn't drain or spin. The problem was it was clogged, in the front when you lift off the washer casing theres a white piece connected to to tubes that drain. well there was my daughters pair of underwear in there and a couple small socks. He took them out put it back together and worked ever since. Until earlier tonight we had same problem so we took it apart ourselves and found my boyfriends sock in there took it out and put it back together and works great again. So far so good. Hope this helps Good luck. Tammy
Nov 05, 2010 | Whirlpool LSR8433K Top Load Washer
Kenmore 48102 Front load washer won't siphon out laundry detergent.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore Energy Star 44092 Front Load...
How to clean a clogged detergent,softener, and bleach dispenser in a front loading washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How to take a washers detergent tray out
Jun 27, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Bleach and fabric softner despenser liquids not being used.
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Kenmore he 2 plus front loading washer
Solution for clogged soap dispenser on Kenmore He2. If you open the door and slightly pull the gray rubber seal away from the drum, at the 10:00 position, you can see if there is an item blocking the inside soap despenser drain pipe. I had a sock stuck in there and I gently used two fingers (one from each hand) to grab the lodged item and pull it out. It no longer looked like a sock, but a torn up washcloth. If this solves your problem, I highly recommend using a mesh laundry bag to wash anything smaller than a washcloth. Socks (all socks, not just a baby's socks), thongs, etc have all gotten stuck in the soap despenser drain and in the water outlet drain filter. They are too torn to be used again, of course but it answers the age-old question of "where did all the matching socks go!"
What I recommend to anyone who has this washer to do their regular cleaning cycle. After you do this, check both drains, the grey rubber seal, etc for anything that may have gotten in here. If you use the mesh bags for anything smaller than a shirt and pants, you will find that the clogged draining problems will happen with less frequency.
Also, before doing expensive repairs, take an hour or two to search the web and see if you can figure out (from customers before you) how to fix these chronic problems. If there is still a problem you can't fix and HAVE to call a repairman, watch the repairman fix the problem so you know how to fix it next time. Not only that but you can tell us what the repairman did so those that have the problem after you, have a way to fix the "simple" fixes.
Jun 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
80 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
