Question about Toshiba CX32H60 TV
Tvdoes not respondto the TVorCable remote to change vol or off/on
Have changed batteries in both of the remotes to no avail. The digital remote works fine to select channels. Will not change volume on tv.
  • paulthia Mar 29, 2009
    tv does not respond to cable remote to change vol or turn off or on.
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
ebrus
  • 30 Answers
SOURCE: Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
Kuwagata
  • 181 Answers
SOURCE: volume and channel up/down keys remote probs
The remote's broken.Find the replacement of the remote with same type, or
if you want to do it yourself, open the remote case, then try cleaning all the rubber pad and the button pad inside the remote using alcohol, this should works.
Posted on Mar 07, 2010
SOURCE: Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Posted on Oct 20, 2010
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control)
Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
I need a code to my remote ...its a one for all ...brand.... and my tv is a sanyo?
did you try to search for 4 digit code? see which model you have. search: press program wait for light to blink twice, press 992, press vol ^ then #1 until tv changes or turns off, then press set, does it work? if you pass code you can repeat steps but use vol dn then press set. i had to send my remote in for up grade didn't cost other than shipping & handling my remote didn't have 6 prongs for them to up grade in battery compartment. or go to all for one remote.
Sep 09, 2009 | Sanyo Televison & Video
Sony av remote
To reset the remote control to the factory default settings, simultaneously press the POWER , TV/VIDEO , and VOL- buttons. Go here for programming instructions; http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMPP412
Sep 03, 2008 | Sony (RM-SP50) Remote Control
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Toshiba CX32H60 TV Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
