Washer just shuts down
We have a Frigidaire front loading washer (ATF6000ESO) that keeps shutting off automatically. Some times at start-up, sometimes during washing. Lights just go off and unit either does not start or stops in the middle of washing. I have tried shutting off main power for 30-min. and it still happens. Any ideas would be helpful. Thanks. Keith
  • Keith Salter Oct 22, 2012
    Add a CMy washer doesn't have a rinse only cycle to try as you suggest. It does have a spin only and yes that cycle works fine. Water drains fine. None of the other cycles will start up. Lights just blink off and unit shuts down. No drain noise. Any other ideas?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Posted on Oct 20, 2012
  • Keith Salter Oct 20, 2012
    My washer doesn't have a rinse only cycle to try as you suggest. It does have a spin only and yes that cycle works fine. Water drains fine. None of the other cycles will start up. Lights just blink off and unit shuts down. Any other ideas?
SOURCE:
Coldcut
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Posted on May 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 02, 2010
SOURCE: my maytag neptune front load washer keeps shutting
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
Posted on May 03, 2010
I HAVE A FRIGIDAIRE AFFINTY LAFW7000LWO WHEN DOOR IS SHUT THE DOOR SENSOR STARTS
Good Afternoon Friend,
I understand that the door sensor goes off on your Frigidaire Affinity washer, model# LAFW7000LW0, when the door is shut. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire ATF6000ES Front Load Washer
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks...
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Dec 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
The impeller became disengaged from the pump motor shaft on my frigidaire affinity front loading tumble washer. (model ATF6000ESO) It was made in 02/2006. Do I need to replace the entire motor/pump...
no the impellar can not be reattached i will not hold and will come off again.I have tried to repair them before and they just do not hold. so you do have to replace the whole pump.
Nov 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Door alingment breaks door switch is there an adjustment atf6000eso front load washing mch
lossen hinge bolts and pull up on door when tightening otherwise replace the hinges
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
