Question about Durabrand DUR7 Portable DVD Player
Durabrand portable d.v.d.player
I say loading.... then it won't load nor read disk? tried alchol to clean "eye" no progress.
My friend give me hers in frustration for the same problem. Turned out to be that little tiny switch under the lid. Inside, just to the right of th play button, is asmall black needle-looking thing sticking up. It's protected by a little plastic fence. This whole thing is less about 5 mm across. To test it, open the lid, then use a pencil or something to hold down the switch ALL THE WAY, then see if the unit springs to life. If so, then look at the bottom of the lid and find the little bump that presses down on the switch. Find some way to build that up a little bit, maybe a few layers of fingernail polish, or a small felt sticker, or some glue. Once it starts pushing that switch down a little further, the unit will work OK. I ended up using a teeny tiny little screw like the kind that mounts a hard drive in a PC, but I had to drill out a hole for it first. I wouldn't do it that way again. Now if that fixes your problem, let me know exactly what that wide/normal switch does! I can't tell if it actuall keep the correct aspect ratio or if it just stretches the picture. Drop me a line at spa_dump@wowway.com and let me know. Hope that helps you out!
Posted on Jun 12, 2007
After loading it reads no valid disc
Either the laser lens eye is dirty and needs to be cleaned with rubbing alcohol and cotton swab or the lens unit is faulty and will need to be replaced
Aug 01, 2009 | Durabrand DUR7 Portable DVD Player
Dvd player
You need to Get a Disk Laser Eye Cleaner. It is like a DVD Or CD But it has Brushes on the Face that will Clean the Reading Lens. This should solve your Problem.
Jan 25, 2009 | Durabrand PDV-705 Portable DVD Player
It cant read a dvd "no disc"
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
Dec 28, 2008 | Durabrand PDV-705 Portable DVD Player
Coby TFDVD5000 wont read disks
just move the laser with your finger, push it to the outside and then tell it to work by the authority of Jesus Christ
Jun 21, 2008 | Coby TFDVD5000 Portable DVD Player
Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Durabrand DUR7 Portable DVD Player
Dvds dont work
have you tried a cleaning disk and make sure the movie disks have no finger prints on them that will stop it from loading.
Nov 24, 2007 | Durabrand PDV-705 Portable DVD Player
Dvd
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Nov 15, 2007 | Durabrand PDV-705 Portable DVD Player
Not playing DVD's
You can clean lense with soft cloth and alchol
Jul 09, 2007 | Durabrand DUR7 Portable DVD Player
Durabrand 8.5 dvd player
Is it the correct type of disc? Whilst these devices will play almost all 'commercial' disks In many cases 'burned disks' Cumputer Data disks and audio disks are a No No The manual/packaging will tell you which. You could try a Lazer cleaner disk. Failing that it looks as if the device is failing and needs replacing - I doubt if there is a repair option.
May 23, 2007 | Durabrand DUR7 Portable DVD Player
Wont read dvd
won't read disk...tried alchol om lens....i'm in arlington tx. any place i can take this to get fixed in my area? dredlock89@yahoo.com
Feb 19, 2007 | Durabrand DUR7 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
42 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
