Question about Toshiba Wireless Mouse PA3205U-1ETC
Wireless mouse how do i setup the wireless mouse to my computer the connection on wireless was usb my original was a usb via a round plug into the computer. I used the connector for the wireless one but nothing happened in fact I then changed back to original one and that did not work either, so turned computer off and then on again and original worked don't know why! Wireless mouse
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Hope this helps. Bud
Posted on Jan 16, 2009
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
My wireless keyboard and mouse has a computer connection of a USB plug and another plug that is round and green with multi pins in it. My new computer does not have a recepticle for the multi pin plug....
The round plug is for older computers that don't have USB. You don't need to concern yourself with it if you have USB. Just use the USB connection and everything will be fine.
Mar 06, 2011 | Logitech Wireless Access Duo Optical...
How do I connect this mouse to my computer?
the mouse is wireless. If you bought the mouse from a store it should have came with a dock, that connects via USB to your PC/Laptop etc.. The dock will be plug and play, which means as soon as you plug it into your PC it will pick-up the device and automatically begin to install the drivers for the device.
Once you have plug the usb dock in, and it has installed the drivers. Aslong as the mice has a charge it will be ready for use.
Nov 16, 2010 | Microsoft Wireless Mobile Mouse 3000
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
Mouse jumps around hard to control
If this is an older wireless mouse setup with two connections to the computer one ps2(round plug) and another usb(flat plug) try restarting the computer with the usb moved to another port. Make sure the ps2 plug is securely plugged in to the correct ps2 port.
Mar 05, 2010 | Logitech Cordless Mouse
I want to install a Microsoft wireless optical mouse but not sure how to do it.
With the wireless mouse you also have a wireless adapter that is connected via usb to your computer. Insert the usb adapter in an available usb port on your computer. Wait for a few seconds until windows verfies and installs the new device. Then press the sync button located under the wireless adapter and at the same time press the sync button under your mouse.
The mouse will be ready to use.
Regards,
nicolasiac
Feb 09, 2010 | Microsoft Basic Optical Mouse PS 2/USB...
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
Wireless mouse
With USB wireless mice, you plug in the USB wireless adapter, and turn on the mouse. Windows XP should automatically install the software, if not, install the software on the disk that the mouse came with (if there is one). If there isn't a disk, Windows XP will most likely install the drivers automatically. Press the connect button on both the mouse, and the USB adapter, and it should all work. Good Luck
Aug 16, 2007 | Microsoft Wireless Notebook Optical Mouse...
Toshiba Wireless Mouse PA3205U-1ETC Logo
206 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
