Question about Euro-Pro Denim Sewlution 380 Mechanical Sewing Machine
Where do I find a bulb for my sewing machine?
    Problem Solver:
  • 12 Answers
Do you have a sewing machine repair shop near you? Walmart? Sears? Clotilde.com?
Posted on Jan 09, 2009
What kind of bulb for the Morse 4300 sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: Bulb 15 Watt Small screw in base A1 Sewing Machine Specialists
Nov 09, 2017 | Sewing Machines
What light bulb fits 4300 Morse sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: https://a1sewingmachine.com/LB716sm~Bulb%2C+15+Watt+Small+screw+in+base.htm . Another source is https://www.sewingpartsonline.com/light-bulb-white-7scw.aspx .
I hope this helps. However, if you have a bulb in the sewing machine, take it out and confirm that it is the screw in type. (If there is no bulb, look at the socket for some turns for threading in a bulb.) If the bulb or socket doesn't have threads, then look for a 15W push and twist bulb at sewing machine parts suppliers.
Nov 08, 2017 | Sewing Machines
How to get the light bulb out of new home 605 sewing machine
A manual may be helpful:
New Home Sewing Machine Manuals Instruction and Repair Manuals
New Home Model 605 Sewing Machine Instruction Manual
Janome New Home sewing machine instruction manuals
http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Sewing_Machines.htm
If it is bayonet type bulb, you may have to push in on the bulb and twist simultaneously. (Rubber fingertips are very helpful!)
Other bulbs simply unscrew.
However, there are also some machines (mostly newer models) which require the bulbs to be replaced by a technician.
Nov 19, 2016 | New Home Sewing Machines
Machine stopped working after bulb fried
it sounds like it's an electrical problem or fuse. you can check with
brother customer service to see if the sewing machine has a hidden
fuse.
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Light bulb not working
You need to change the bulb.
Most light bulbs in almost all sewing machines are located inside the face plate on the left hand side of the machine.
The faceplate is usually hinged at the back and it opens a bit like a door. It should open fairly easily and close with a click.
Open the faceplate and unscrew the bulb, it should be in plain view.
Look to see if it a screw or bayonet type.
Replace it the same way you would an ordinary bulb.
You can get sewing machine bulbs on ebay but you'll need to know which type of fitting it has before you buy.
Hope this helps!
Nov 10, 2010 | Singer 7462 Mechanical Sewing Machine
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
I bought a new sewing machine light bulb to replace the one that burned out but can't get it ot screw in the socket. Are all sewing machines bulbs universal?
your bulb part number is X53061020 and no the blubs are not universal I would suggest taking the old bulb with you along with the part number I gave you in order to get the right bulb when you go to the store.
Sep 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bulb is fused
There is no problem if the bulb was busted,just dismatle it replace a new one.Open face cover plate where the bulb was socket.turn bulb in left drection from the socket to pull out.Be sure the power was off no power supply). replaced a new one.
Feb 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Replacement lightbulb, model 1500, 12v6W
Here is the toll free number to White. 1-800-331-3164 or go to www.whitesewing.com. Perhaps you can order the part. I have a Sears Kenmore sewing machine. My light bulb went out after 35 years. Can you believe it?? I finally found the bulb at a local sewing machine center however, they wanted $9.00 per bulb.. Walmart, Target, Joanns etc., did not have the bulb. I called the sears part center and obtained the bulb there. The cost was $4.00 for a pack of 2. After all the hunting I did, the S&H was well worth it. Good luck and I hope this helps you.
Nov 17, 2008 | White Sewing Speedylock 1600 Mechanical...
Euro-Pro Denim Sewlution 380 Mechanical Sewing Machine Logo
53 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
