Question about Maytag Neptune MAH5500B Front Load Washer
Water in outer tub in washer cannot drain please suggest me how to fix this problem without calling any tech i will be greatful to maytag co. thanking you anil.
WHAT YOU NEED TO DO IS , PURCHASE YOU A HOSE CLAMP TO CLAMP DOWN HOSES THAT GO FROM TUB TO PUMP AND DRAIN TO PUMP, BECAUSE YOUR WASHER IS FULL OF WATER, AND YOU DO NOT WANT A FLOOD TO HAPPEN,,OR YOU CAN TAKE IT OUTSIDE, TAKE THE HOSE OFF THE PUMP AND EITHER TAKE THE PUMP OFF AND CLEAN OR REACH YOUR FINGERS IN HOLD AND GRAB DEBRI OUT... WHITES APPLIANCE REPAIR 404-468-2208 IN LITHONIA MARCWHITE33@COMCAST.NET
Posted on May 16, 2007
Drain pump blocked
Posted on May 13, 2007
SOURCE:
I have a Maytag Atlantis MAV6200AWW. It often does not empty out the tub when it is finished, and the water is still soapy after it is done. If I turn it back to spin it does and drains ok.
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.If the drain line isn't plugged, the problem may be with your pump.
Jan 06, 2011 | Maytag Atlantis MAV6000 Top Load Washer
We have a Maytag MD-24 Front Load Washing Machine. The Pump gets plugged. It is usually a quarter or something of that size that plugs the pump. Right now the machine has water in it. How do I drain the...
HI,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jul 19, 2008 | Maytag Washing Machines
Maytag top load replaced belts and still washer will leave water on spin cycle half full. If I play around with it I can get it to drain
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 26, 2010 | Maytag PAV2300 Top Load Washer
Maytag Neptune washer front loader has been great but my wife pointed out that it doesn't drain all the water out? The thought of that old water under the spinning basket (dont know the tech term) doesnt...
Yes, the Neptune is a great washer, arguably. :-> You just may have a clogged pump. Pull the back panel and the rest is evident. Pull baffles, remove gookus, pull pump, clean, etc. ...just like a plumber. Be sure to pull the rubber baffe directly from the bottom of the outer tub. You may need a wet/dry vac to assist you. It's a bear of a job but I do it all the time.
Rich
Western Appliance Repair
Washer Repair Meridian
Oct 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water doesn't drain when spinning in rinse cycle.
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Oct 27, 2009 | Maytag Washing Machines
Maytag Neptune leaks several hrs. AFTER I finish using it.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
if that is checked then ---------------
t leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
THE WASHING MACHINE IS LEAKING A OIL LIKE FLUID UNDER THE MACHINE?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Jul 18, 2008 | Maytag Performa LAT2500A
Won't empty water slow spin in spin cycle
if this helps please vote a fix ya
Jul 15, 2008 | Maytag PAV2300 Top Load Washer
Washer wont drain water
It won't drain If your washer won't drain, check these:
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
339 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
