Question about GE 24 in. GLD6500L Built-in Dishwasher
GE GLD6500LOOBB Washer makes a growling or grinding noise during wash cycle operation. I believe it may be one or more of the rotating wash arms not seated properly and vibrating when spinning. Otherwise the washer works great. The washer is 19 months old, and this just starting doing this within this past month. Any ideas or suggestions.
  • 87 Answers
Open the door quikley while the washer is running. Is the spray arm spraying up and rotating. If not you may have a bad seal under the spray arm or a cracked one.
Posted on Jun 08, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
I have a GE front-loading washer. There is a horrible thumping noise as the drum turns. It is not constant - when I turn it by hand it seems to "thump" on every rotation of the drum. I ran it...
The thumping sound is a sure sign that the spider arms or the support arms that hold the wash drum are broken. It is a very expensive repair since you need to buy a replacement wash drum and spider arm assembly which almost cost as much as new washer. Get a few estimates before deciding whether to repair or replace the washer. Sorry.
Apr 23, 2011 | GE WSXH208A Front Load Washer
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
GE dishwasher model GLD4200 making a growling noise
I do not know of these machines but would say it sounds like bearings related to its rotating arm if it has to deal with water.
It would have a seal at the back before the bearings which has failed so water has leaked onto it causing rust to form in the bearing which builds up fuses the ball bearings together in clumps, make it hard to rotate so you get a grinding noise followed later by squeaks as things deteriorate.
So sadly it needs a service call out or it will grind to a halt, this happens say after a few days of non use letting the rust level build up.
You can use it but at some point it will not be able to rotate and it will just stop with some odd error message if it has that ability. Sorry for the answer.
Hope this helps...........
Apr 27, 2017 | GE GLD4200L Built-in Dishwasher
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Noisy dishwasher
This is a known issue for GE dishwashers and may be similar for other models too.  The fix is simple.  The noise is due to vibration of the arm for the middle sprayer.  Just secure it with a tie wrap or wire and the noise should be gone.
Refer to the following link for my earlier response to a similar issue which fixed the problem.
http://www.fixya.com/support/t204050-ge_adorda_dishwasher
Oct 26, 2007 | Dishwashers
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
GE 24 in. GLD6500L Built-in Dishwasher Logo
344 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
