Question about Insignia Televison & Video
Red/yellow static lines running through the screen/no picture
Insignia flat screen tv model # NS-42PDP
Serial # 16669PH42FB6001273
Lot # 93411
Manufactured: June 2006
This TV was purchased over a year ago however it has only been used a minimal amount of time. It sat for over 8 months without use and has never been connected to cable. We recently started to use it and after a couple of uses it died. You no longer get a picture, you just see fuzzy horizontal and vertical lines (red/yellow) running across the screen. Can you help?
  • 8 more comments
  • topcop1809 Jan 01, 2009
    this is a large screen tv LCD but manufactured in 2006
    the longer the tv stays on you begin to see two large white horizontal blocks show up
    if it is, is it worth fixing, what does something like that cost?
    more advise?
    the remote does work and we do have sound
    thxs
    any other comments?
    I attempted the unplug and replug...same results
    thank you
    Sorry, not really sure how to respond. Your response was great, thank you for your help
  • 10,594 Answers
Do you get sound of cable channels? Does remote work and can you reduce / increase volume through remote? Let me know to help you.
Posted on Jan 01, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jan 01, 2009
    OK, as you said remote works and you have sound.
    TV needs LCD Controller board and you can buy it from Shop Jimmy.
    Price is just $50
    If you know how to apart TV and swap board, you can do it yourself.
    Good luck.
    hehe, I gave you solution and you rejected it with Thank you?
    Now I would say Thank You.. :D
  • Insignia Master
  • 19,396 Answers
Try first unplugging the TV set for ten minutes or so, by unplugging the power cable for a while.
If this does not work it is probably one of the STK ICs that regulate the convergence that has blown, in this case it its better to call a technician, as the TV must be takeen apart, tested , and the faulty component removed.
  • Ginko
    Ginko Jan 01, 2009
    If this is an LCD, then convergence is not controlled by convergence board, but from ICS often located on video controller board, that is the main board on this set.
    Replacing the main board is expensive, and may not be worth repairing, as to the board you add the repair cost.
    Faults related to LCD ribbon cable can also give you similar problems. In this case the part will be quite inexpensive, and the repair still worth.
    Also faults concerning the power board and other minor faults can give you display disturbance, even if this is not very common.
    The TV must be tested to find out.
    Try also connecting a different antenna, receiver or computer to the TV, problems with frequency signal and bad cables can give you similar lines.
  • Ginko
    Ginko Jan 01, 2009
    hehe, We all gave you solution and you rejected it with Thank you?
    Now are we supposed to say say Thank You.. :D?
    Genius:
  • 1,199 Answers
It sounds to me like the power transformer unit has went out and will need replaced!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
My gues is, it's a big screen, lcd, or something late model
On the insignia NS-39d400na14 im trying to hook up my playstation 2, i can see it on the screen but i don't have color and don't have any other cables i can use to add color, can i change settings
YOU HAVE NO COLOR DUE TO PLUGING YELLOW , WHITE AND RED INTO COMPONENT INPUTS, USE YELLOW PLUG FROM PS2 INTO GREEN ON TV IF YOU DONT HAVE A YELLOW JACK ON TV, RED AND WHITE ARE FOR AUDIO IN ONLY. Colorvision Services
Oct 30, 2014 | Televison & Video
Insignia NS-42PDP plasma tv turn off on its own and can't be turned without disconnecting power and the restarting
You possibly have bulged capacitor on power supply, just replace it to fix the problem
Dec 03, 2012 | Televison & Video
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
I need a remote code for my insignia tv model NS-CL19C Serial # DC0UEOEO300DW78X0288
Many remote control codes can be found at InsigniaProducts.com. Just search for your TV model number and click Support!
Jun 29, 2010 | Insignia NS-LCD19 19 in. LCD TV
Two questions: My Insignia NS-LTDVD 19 flat
This model/brand of LCDs does need a digital converter since they are a low end quality product, the manufacturers did not put an ASTC tuner to decode the HD signals.
The DVD assembly can be replace to fix the DVD issues.
I have a couple of these DVDs assemblies from a broken screens LCDs and they're like new condition.
Let me know if you need further assistance.
Jun 23, 2010 | Insignia NS-LTDVD19-09 LCD TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Red Snow
Sounds like you know what your doing so i won't get over technical on ya ! Diffusion is the name for the problem.Adjust the VA and VS, if that doesn't cure it the panel is bad.
Jun 11, 2009 | Televison & Video
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
70 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
