It stoped receiving digital channels. it will stop on channel but no talk and starts scanning again. when it stops on channel it dose not say anything just stops and then continues to scan to next channel. analog trunking works just digital is not working. i have tried to redownload programing and tried to reset. i use win 96 to program my scanner.
I have the same problem. A good shake restores the digital channels to working order for a few hours again.
I think I have a cold solder joint or similar internal problem. I've only had it a few months.
Since a quick shake cures it, I'm not going to return it yet. But it could be that there is something going on with the internals.
SOURCE: Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
it was working fine yesterday all i did was cut it off and cut it back on a couple of hours later. then it just stopped transmitting digital voice. analog still works.
