Question about Whirlpool LEB6200 Electric Dryer
Whirlpool dryer, LER5636JQO, long drying time
Airflow seems good; I've checked for any blockage. The dryer heats. Does this mean I need a new coil?
  • webb_jr Feb 09, 2009
    heat comes on for about 15-30 seconds then goes off wil come back on after 1 minute or more then will go off as above.
  • Thomas F. Schneider May 11, 2010
    If you have it set on high heat and  it is only warm then yes it usually meant that the heater element is partly shorted and needs to be replaced. Isolate the element and OHM it out. It should read a fairly large resistance.
  • Whirlpool Master
  • 3,463 Answers
Not always the case, as there are at least 2 thermostats that could cause the prob, if it is getting hot, then perhaps only part of the element is heating, also make sure u have high heat selected.
U really need to access the heater and stats to check them.
Plz rate this solution.
Thanks.
Posted on Jan 01, 2009
How do I get the front off of this appliance. I can remove the 2 top screws but do not know how to get the front off so that I may vacum it cleanly as this may be my solution to the heat on and off problem I am having. Hope this dont sound too dumb of a question.
Posted on Feb 10, 2009
My whirlpool ler5636jqo electric dryer reun fine for 5 minutes then turns off.the cloths have heat and are still damp. when its run in fluff mode{no heat}, the dryer runs the entire cycle. Vent and exhaust...
Yes Bruce, I'd suggest cleaning the lint out of the blower intake under the lint basket. Then remove the flex duct off the back and clean the discharge of the blower as good as possible. Even check for build up inside the flex duct and outdoor termination. What you are experiencing is the typical 'lack of airflow' causing an increase in temperature rise across the heating elements which results in the tripping of the high temp limit switch. If those areas are clean as you indicate, the problem is within the confines of the blower assembly itself and blower wheel itself.
Many times, the top has to be raised and the front removed to facilitate proper cleaning of the blower and related areas. If so MAKE SURE YOU UNPLUG IT FIRST !!!!! Mark all wires that may have to be removed or write inside the white surfaces your notes about wire color and location with a majic marker.
Mar 08, 2015 | Whirlpool Dryers
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
Dryer heats but does not dry
you have an airflow problem, check your dryer venting to the outside of your house you may find a blockage or restriction
May 27, 2010 | Whirlpool LER5636P Electric Dryer
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
My dryer takes a long time to dry the cloths
Hello Friend, You didn't state in your discription if you dryer was igniting or if heating element was actually coming on or not. But here is a possible solution to your problem. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 29, 2009 | Whirlpool Dryers
Whirlpool dryer wont dry.
LONG dry time is an indication of a clogged or restricted exhaust. Check the exhaust hose in the rear of the machine and make sure it is not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this website:http://www.linteater.com.
Jul 05, 2008 | Whirlpool LEB6200 Electric Dryer
I have a Whirlpool dryer model #LEN200LWO. It takes 3-4 times through the cycle to finally get the clothes dry. I've noticed too that there doesn't seem to be much lint on the screen - which I clean before...
bad airflow definitely bad airflow use real metal vent hose not the coil and plastic or mylar. make sure the vent at the outside wall is not stopped up somewhere there is a blockage
May 07, 2008 | Dryers
I have a Whirlpool Model LGR5620KQ Heat Problem ....
Here's a site that shows exploded view parts diagrams for your model, which can be useful when working on it. --> http://www.partselect.com/MultiModels.aspx?ModelNum=LGR5620KQ&searchTerm=&RefineSearch=0 A dryer needs two things, heat & airflow. If you have the heat, look for a kinked vent hose or a blocked vent louver where it blows outside the house. If that doesn't help, write more and we'll keep trying.
Aug 10, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LEB6200 Electric Dryer Logo
399 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
