Lack of Virus information
VBS.Autorun.Nar-1 is a virus I have encountered and want to know more about so I can be sure more of my computers have no9t and will not be re-infected and if they do what damage will this virus do?
  • 585 Answers
It's not a virus, but a worm. It's intent is to hjack your browser. It will download things, like popups, and ads, that you would not want. You shouldn't need to worry about it if you keep your anti-virus and anti-spyware applications up to date. If you feel the machine is infected, restart the machine in safe mode, run a scan with your anti-virus/spyware software, and allow it to fix what it finds.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 02, 2009
Autorun
Remove Computer Virus
Remove Computer Autorun Virus
When I copy any data from removable disk A Folder auto copy in every folder
1.You should install a update antivirus and scan all drive .[antivirus like avast / Symantec etc.]
2.Your problem must be solve.100%
May 10, 2013 | PNY 8GB HP c500w USB Drive
When i start my windows a dialog box named WINDOWS HOST SCRIPT APPEARS and says some message about rahul's virus protection
Hi karthicku683,
Your computer is infected with viruses. Please use a good anti-virus software to keep your system clean.
1) Right click on the taskbar and click 'Task Manager'.
2) In the 'Process' tab find wscript.exe.
3) Right click on it and select 'End Process Tree'
4)
Go to Folder Options and check show hidden files and click OK.
5) Delete 'VirusRemoval.vbs' and 'Autorun.inf files' from all usb drives and hard drives.
6) Then go to C:\Windows\System32 and delete the file 'VirusRemoval.vbs'.
7) Next go to START>RUN and type regedit and Enter.
8) Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
9) On the right side look for Shell which should have value of just explorer.exe. Delete anything at right side of explorer.exe if there is anything.
10) Under same key Winlogon also look for Userinit which should have value of C:\WINDOWS\system32\userinit.exe.
11) Delete all the **** after the comma.
12) Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Hope this solves your problem. If this information was helpful, please rate this solution.
Thank you for using fixya.
Arun Zac
Nov 24, 2010 | Computers & Internet
How to remove sowar virus on my pc
1. Go to Start, Run and type: cmd press Ok.
2. At the command prompt, type in your primary drive location, usually C:
3. You may need to change the directory. If so type: cd \ hit Enter.
4. Type: attrib -s -h -r -a autorun.inf hit Enter.
5. Type: dir and hit Enter. This will allow you to see and confirm the Autorun files.
6. Type: del autorun.inf hit Enter. Repeat the above commands for each drive on your computer including your flash/usb drive.
7. Now search for and remove sowar.vbs, SysRes.vbs, Cool USEP Scandal.vbs
  • At the command prompt, type in your primay drive location, usually C: hit Enter.
  • Type: attrib sowar.vbs.* -s -h -r -a hit Enter.
  • Type: dir /s sowar.vbs Hit Enter.
8. If the file is present, type: del sowar.vbs hit Enter.
  • Repeat the above commands for each drive on your computer including your flash/usb drive.
  • Then repeat these instructions to search for and delete SysRes.vbs, Cool USEP Scandal.vbs on each drive if present.
9. Exit the command prompt and reboot normally.
10. Disable autorun.
Dec 21, 2009 | Microsoft Windows Server Standard 2003 for...
Pendrive has a file-CleanVirus.vbs...wat does it do...
Iam having a 4 gb Kingston make pen drive which is giving virus problem.ie clean virus.vbs when ever im inserting in comp. and trying to open or auto play the same message is appearing pl help me how to get rid off from this problem
Jun 09, 2009 | Samsung SGH-D900 Cellular Phone
Cannot access anti-virus websites
Download STINGER antivirus and scan with this tool.
Variants Can Detect:
BackDoor-ALI,BackDoor-AQJ,BackDoor-AQJ.b,BackDoor-CEB,BackDoor-CEB!bat,BackDoor-CEB!hosts,BackDoor-CEB.b,BackDoor-CEB.c,BackDoor-CEB.d,BackDoor-CEB.dll,BackDoor-CEB.dr,BackDoor-CEB.e,BackDoor-CEB.f,BackDoor-CEB.sys,BackDoor-CFB,BackDoor-JZ,BackDoor-JZ.dam,BackDoor-JZ.dr,BackDoor-JZ.gen,BackDoor-JZ.gen.b,Bat/Mumu.worm,Cleanup,CoreFlood,Coreflood!psexec,Coreflood.dldr,CoreFlood.dll,CoreFlood.dr,Danmec,Downloader-DN.a,Downloader-DN.b,Downloader-UA,Exploit-DcomRpc,Exploit-DcomRpc.b,Exploit-DcomRpc.dll,Exploit-Lsass,Exploit-Lsass.dll,Exploit-MS04-011,Exploit-MS04-011.gen,Exploit-MSExcel.k,Exploit-MSExcel.l,Exploit-MSExcel.m,Exploit-MSExcel.n,Exploit-MSExcel.o,Exploit-MSExcel.p,Exploit-MSExcel.q,Exploit-MSExcel.r,Exploit-PDF.b,Exploit-PDF.c,Exploit-PDF.d,Exploit-PDF.e,Exploit-PDF.f,Exploit-PDF.g,Exploit-PDF.h,Exploit-XMLhttp.d,Exploit-XMLhttp.d.gen,Exploit-XMLhttp.d.gen.b,Exploit-XMLhttpd.d,FakeAlert,FakeAlert-AA,FakeAlert-AB,FakeAlert-AB!htm,FakeAlert-AB.dldr,FakeAlert-AB.dr,FakeAlert-AC,FakeAlert-AD,FakeAlert-AE,FakeAlert-AF,FakeAlert-AG,FakeAlert-AG.gen.b,FakeAlert-AG.gen.c,FakeAlert-AH,FakeAlert-AI,FakeAlert-AJ,FakeAlert-AK,FakeAlert-AL,FakeAlert-AM,FakeAlert-AN,FakeAlert-AntiVirusPro,FakeAlert-AntiVirusXP,FakeAlert-AO,FakeAlert-AP,FakeAlert-AQ,FakeAlert-AR,FakeAlert-AS,FakeAlert-AT,FakeAlert-AU,FakeAlert-av360,FakeAlert-AW,FakeAlert-AZ,FakeAlert-AZ!htm,FakeAlert-B,FakeAlert-B.dldr,FakeAlert-B.dr,FakeAlert-BA,FakeAlert-BB,FakeAlert-BC,FakeAlert-BD,FakeAlert-BE,FakeAlert-BE.gen,FakeAlert-BF,FakeAlert-BG.dldr,FakeAlert-BH.dldr,FakeAlert-BI,FakeAlert-BJ,FakeAlert-BK,FakeAlert-BL,FakeAlert-BM,FakeAlert-BN,FakeAlert-BO,FakeAlert-BO.dldr,FakeAlert-BP,FakeAlert-BQ,FakeAlert-BR,FakeAlert-BS,FakeAlert-C,FakeAlert-C.dr,FakeAlert-C.gen,FakeAlert-D,FakeAlert-E,FakeAlert-F,FakeAlert-G,FakeAlert-H,FakeAlert-I,FakeAlert-J,FakeAlert-K,FakeAlert-L,FakeAlert-LastDefender,FakeAlert-M,FakeAlert-N,FakeAlert-N.dldr,FakeAlert-O,FakeAlert-P,FakeAlert-Q,FakeAlert-R,FakeAlert-S,FakeAlert-S.dll,FakeAlert-SpyKiller,FakeAlert-SpywareGuard,FakeAlert-T,FakeAlert-U,FakeAlert-V,FakeAlert-W,FakeAlert-WinwebSecurity,FakeAlert-X,FakeAlert-XPAntivirus,FakeAlert-XPSecCenter,FakeAlert-Y,FakeAlert-Y.dr,FakeAlert-Z,Fribet,Generic FakeAlert,Generic FakeAlert.d,Generic FakeAlert.e,Generic!atr,HideWindow,HideWindow.dll,HTool-T2W,IPCScan,IRC/Flood.ap,IRC/Flood.ap.bat,IRC/Flood.ap.dr,IRC/Flood.bi,IRC/Flood.bi.dr,IRC/Flood.cd,JS/Autorun.worm.ci,JS/Downloader-AUE,JS/FakeAlert,JS/FakeAlert-AB.dldr,NTServiceLoader,ProcKill,Proxy-Agent.af,Proxy-Agent.af.dr,PWS-Banker.dldr,PWS-FireMing,PWS-FireMing.dll,PWS-FireMing.dr,PWS-Gamania.gen.a,PWS-Narod,PWS-Narod.dll,PWS-Narod.gen,PWS-Sincom,PWS-Sincom.dll,PWS-Sincom.dr,rootkit,VBS/Autorun.bj,VBS/Autorun.worm.au,VBS/Autorun.worm.ay,VBS/Autorun.worm.bi,VBS/Autorun.worm.bj,VBS/Autorun.worm.bs,VBS/Autorun.worm.by,VBS/Autorun.worm.ca,VBS/Autorun.worm.cy,VBS/Autorun.worm.dm,VBS/Autorun.worm.dn,VBS/Autorun.worm.dn!atr,VBS/Autorun.worm.dn!txt,VBS/Autorun.worm.dv,VBS/Autorun.worm.dz,VBS/Autorun.worm.en,VBS/Autorun.worm.k,VBS/Autorun.worm.k!bat,VBS/Autorun.worm.zd,VBS/Autorun.worm.ze,VBS/Autorun.worm.zl,VBS/Autorun.worm.zn,VBS/FakeAlert-AB,VBS/IE-Title,Vundo,Vundo.dldr,Vundo.dr,Vundo.gen.h,Vundo.gen.i,Vundo.gen.j,Vundo.gen.k,Vundo.gen.l,Vundo.gen.m,Vundo.gen.n,Vundo.gen.o,Vundo.gen.p,Vundo.gen.r,Vundo.gen.s,Vundo.gen.t,Vundo.gen.u,W32/Anig.worm,W32/Anig.worm.dll,W32/Autorun.worm,W32/Autorun.worm!inf,W32/Autorun.worm!ini,W32/Autorun.worm.a,W32/Autorun.worm.aa,W32/Autorun.worm.ab,w32/autorun.worm.ac,W32/Autorun.worm.ad,W32/Autorun.worm.ae,W32/Autorun.worm.af,W32/Autorun.worm.ag,W32/Autorun.worm.ai,W32/Autorun.worm.aj,W32/Autorun.worm.ak,W32/Autorun.worm.al,W32/Autorun.worm.am,W32/Autorun.worm.an,W32/Autorun.worm.ao,W32/Autorun.worm.ap,W32/Autorun.worm.aq,W32/Autorun.worm.ar,W32/Autorun.worm.as,W32/Autorun.worm.at,W32/Autorun.worm.av,W32/Autorun.worm.aw,W32/Autorun.worm.ax,W32/Autorun.worm.az,W32/Autorun.worm.b,W32/Autorun.worm.b.cfg,W32/Autorun.worm.ba,W32/Autorun.worm.bb,W32/Autorun.worm.bc,W32/Autorun.worm.bd,W32/Autorun.worm.be,W32/Autorun.worm.bf,W32/Autorun.worm.bg,W32/Autorun.worm.bh,W32/Autorun.worm.bk,W32/Autorun.worm.bl,W32/Autorun.worm.bm,W32/Autorun.worm.bn,W32/Autorun.worm.bo,W32/Autorun.worm.bp,W32/Autorun.worm.bp!reg,W32/Autorun.worm.bq,W32/Autorun.worm.br,W32/Autorun.worm.bt,W32/Autorun.worm.bw,W32/Autorun.worm.bx,W32/Autorun.worm.bx!inf,W32/Autorun.worm.bx.gen,W32/Autorun.worm.bz,W32/Autorun.worm.c,W32/Autorun.worm.cb,W32/Autorun.worm.cb.dr,W32/Autorun.worm.cc,W32/Autorun.worm.cd,W32/Autorun.worm.ce,W32/Autorun.worm.cf,W32/Autorun.worm.cg,W32/Autorun.worm.ch,W32/Autorun.worm.cj,W32/Autorun.worm.ck,W32/Autorun.worm.cm,W32/Autorun.worm.cn,W32/Autorun.worm.co,W32/Autorun.worm.cp,W32/Autorun.worm.cp!bat,W32/Autorun.worm.cq,W32/Autorun.worm.cr,W32/Autorun.worm.cs,W32/Autorun.worm.ct,W32/Autorun.worm.cu,W32/Autorun.worm.cv,W32/Autorun.worm.cw,W32/Autorun.worm.cx,W32/Autorun.worm.cz,W32/Autorun.worm.d,W32/Autorun.worm.da,W32/Autorun.worm.db,W32/Autorun.worm.dc,W32/Autorun.worm.dd,W32/Autorun.worm.dd!inf,W32/Autorun.worm.de,W32/Autorun.worm.df,W32/Autorun.worm.dg,W32/Autorun.worm.dh,W32/Autorun.worm.di,W32/Autorun.worm.dj,W32/Autorun.worm.dk,W32/Autorun.worm.dl,W32/Autorun.worm.dn,W32/Autorun.worm.do,W32/Autorun.worm.dp,W32/Autorun.worm.dq,W32/Autorun.worm.ds,W32/Autorun.worm.dt,W32/Autorun.worm.du,W32/Autorun.worm.dw,W32/Autorun.worm.dx,W32/Autorun.worm.dy,W32/Autorun.worm.e,W32/Autorun.worm.ea,W32/Autorun.worm.eb,W32/Autorun.worm.ec,W32/Autorun.worm.ed,W32/Autorun.worm.ef,W32/Autorun.worm.eg,W32/Autorun.worm.ei,W32/Autorun.worm.ej,W32/Autorun.worm.ek,W32/Autorun.worm.el,W32/Autorun.worm.em,W32/Autorun.worm.eo,W32/Autorun.worm.ep,W32/Autorun.worm.eq,W32/Autorun.worm.f,W32/Autorun.worm.g,W32/Autorun.worm.gen!job,W32/Autorun.worm.gen.cl,W32/Autorun.worm.gen.za,W32/Autorun.worm.gen.zb,W32/Autorun.worm.h,W32/Autorun.worm.h!lnk,W32/Autorun.worm.i,W32/Autorun.worm.j,W32/Autorun.worm.l,W32/Autorun.worm.m,W32/Autorun.worm.n,W32/Autorun.worm.o,W32/Autorun.worm.p,W32/Autorun.worm.q,W32/Autorun.worm.r,W32/Autorun.worm.remmants,W32/Autorun.worm.s,W32/Autorun.worm.t,W32/Autorun.worm.u,W32/Autorun.worm.v,W32/Autorun.worm.v!bat,W32/Autorun.worm.w,W32/Autorun.worm.x,W32/Autorun.worm.y,W32/Autorun.worm.z,W32/Autorun.worm.zc,W32/Autorun.worm.zf,W32/Autorun.worm.zg,W32/Autorun.worm.zh,W32/Autorun.worm.zi,W32/Autorun.worm.zj,W32/Autorun.worm.zk,W32/Autorun.worm.zm,W32/Bagle,W32/Bagle!eml.gen,W32/Bagle!pwdzip,W32/Bagle.ad!src,W32/Bagle.dldr,W32/Bagle.dll.dr,W32/Bagle.eml,W32/Bagle.fb!pwdzip,W32/Bagle.fc!pwdzip,W32/Bagle.fd!pwdzip,W32/Bagle.fe!pwdzip,W32/Bagle.fm.dldr,W32/Bagle.gen,W32/Bagle@MM!cpl,W32/Blaster.worm,W32/Blaster.worm.k,W32/Bropia.worm,W32/Bugbear,W32/Bugbear.a.dam,W32/Bugbear.b!data,W32/Bugbear.b.dam,W32/Bugbear.gen@MM,W32/Bugbear.h@MM,W32/Bugbear@MM,W32/Conficker,W32/Conficker.sys,W32/Conficker.worm,W32/Conficker.worm!inf,W32/Conficker.worm!job,W32/Conficker.worm.gen.a,W32/Conficker.worm.gen.b,W32/Deborm.worm.ah,W32/Deborm.worm.gen,W32/Doomjuice.worm,W32/Dumaru,W32/Dumaru.ad@MM,W32/Dumaru.al.dll,W32/Dumaru.dll,W32/Dumaru.eml,W32/Dumaru.gen,W32/Dumaru.gen@MM,W32/Dumaru.w.gen,W32/Elkern.cav,W32/Elkern.cav.c,W32/Elkern.cav.c.dam,W32/Fizzer,W32/Fizzer.dll,W32/Fujacks!htm,W32/FunLove,W32/FunLove.apd,W32/Gaobot.worm,W32/Harwig.worm,W32/IRCbot,W32/IRCbot.worm,W32/IRCbot.worm.dll,W32/Klez,W32/Klez.dam,W32/Klez.eml,W32/Klez.gen.b@MM,W32/Klez.rar,W32/Koobface.worm,W32/Korgo.worm,W32/Lirva,W32/Lirva.c.htm,W32/Lirva.eml,W32/Lirva.gen@MM,W32/Lirva.htm,W32/Lirva.txt,W32/Lovgate,W32/Mimail,W32/Mimail.c@MM,W32/Mimail.i!data,W32/Mimail.q@MM,W32/MoFei.worm,W32/MoFei.worm.dr,W32/Mumu.b.worm,W32/Mydoom,W32/Mydoom!bat,W32/Mydoom!ftp,W32/Mydoom.b!hosts,W32/Mydoom.dam,W32/Mydoom.t.dll,W32/Mytob,W32/Mytob.gen@MM,W32/Mytob.worm,W32/MyWife,W32/MyWife.dll,W32/MyWife@MM,W32/Nachi!tftpd,W32/Nachi.worm,W32/Netsky,W32/Netsky.af@MM,W32/Nimda,W32/Nimda.dam,W32/Nimda.eml,W32/Nimda.gen@MM,W32/Nimda.htm,W32/Nuwar,W32/Nuwar.dam,W32/Nuwar.sys,W32/Nuwar@MM,W32/Nuwar@MM!rar,W32/Pate,W32/Pate!dam,W32/Pate.dam,W32/Pate.dr,W32/Polip,W32/Polip!mem,W32/Polybot,W32/Polybot.bat,W32/Sasser.worm,W32/Sasser.worm!ftp,W32/Sdbot,W32/Sdbot!irc,W32/Sdbot.bat,W32/Sdbot.cli,W32/Sdbot.dll,W32/Sdbot.dr,W32/Sdbot.worm,W32/Sdbot.worm!ftp,W32/Sdbot.worm.bat.b,W32/Sdbot.worm.dr,W32/Sdbot.worm.gen,W32/Sdbot.worm.gen.a,W32/Sdbot.worm.gen.b,W32/Sdbot.worm.gen.c,W32/Sdbot.worm.gen.d,W32/Sdbot.worm.gen.e,W32/Sdbot.worm.gen.q,W32/Sober,W32/Sober!data,W32/Sober.dam,W32/Sober.eml,W32/Sober.f.dam,W32/Sober.g.dam,W32/Sober.q!spam,W32/Sober.r.dr,W32/Sober.r@MM,W32/Sobig,W32/Sobig.dam,W32/Sobig.eml,W32/Sobig.f.dam,W32/Sobig.gen@MM,W32/Spybot.worm,W32/SQLSlammer.worm,W32/Swen,W32/Swen@MM,W32/Virut,W32/Virut!mem,W32/Yaha.eml,W32/Yaha.gen@MM,W32/Yaha.y@MM,W32/Yaha@MM,W32/Zafi,W32/Zafi.b.dam,W32/Zindos.worm,W32/Zotob.worm,W32/Zotob.worm!hosts
Download v10.0.0.482 [2,641,920 bytes] (01/10/2009).
Hope this will be helpfull
Thanks & Regards
Nanda Kishore :)
Mar 25, 2009 | Microsoft Windows XP Professional
Can not find script file "C:\ntidr.vbs"
by alvin:
just go to command prompt, click run then type cmd..
after that type dir f:\/a/w if letter f is where your drive located..then you can see the contents of your drive ..you will see an autorun.inf...
you should delete that...in the same cmd window
type attrib -r -a -s -h f:\autorun.inf
then type del f:\autorun.inf....eject your flashdrive...goobye ntidr.vbs..
Sep 21, 2008 | Microsoft Windows XP Home Edition
ABOUT MY 2GB PEN DRIVE WARRANTY
Here's what you should do. actually I prefer using DOS to do this. ok, so fire up the DOS and goto C:
this virus actually put two files on each partition that It will infect, autorun.inf and the .vbs file which contains the code of the virus. currently the attributes of these two files are hidden, read-only and system. so using attrib command, type:
attrib -h -r -s autorun.inf
attrib -h -r -s m*.vbs
del m*.vbs
del auto*.inf
also look for the windows folder and look for the other .vbs file of the virus and change its attribute.
not yet done.
activate your task manager(ctrl-alt-del) and look for wscript.exe, you should end this task.
take not you must do this in every partition or flashdisk that have been infected. Take note you should also check the registry since this virus append it's .vbs to the [Run] field of the registry and also it alters the Title of your Internet Explorer to Hacked by Godzilla.
after your done, you need to reboot your system.
Jun 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Rundll64.dll.vbs virus in my pc
The worm copies itself to the root folder of writable drives, and adds an autorun.inf file in an attempt to execute itself when the drive is mounted.
When run, the worm copies itself to <Windows>\RUNDLL64.dll.vbs
The following registry entry is created to run RUNDLL64.dll.vbs on startup:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
MSConfigs
So, when you will click on any drive it will not be open it just try to run that INF file.
If you have any anti virus scan your system or click here for a free demo of Avira Anti Virus Sacanner.
Thanks
Iqbal
Apr 08, 2008 | Intel Motherboard
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Jan 24, 2008 | Computers & Internet
Missing file after avg "healing"
Yes easy fixed. Open from my computer then go into folders options and click on show hidden folders option, your system folder should show up then open that folder and youll see the vbs file. Delete it, and all is good !
Jan 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
