Question about HP PhotoSmart 145 InkJet Printer
Photosmart 145 fix
No guarantees here, but this worked for me. If you are attempting to use the printer as a stand-alone, do this. Using a standard USB printer cable, connect the printer to any computer. Turn the printer on. The computer should prompt a request for the disc containing the drivers to be installed. As I don't know where my disc is, I tried to skip the process. After clicking through one or two windows, I looked at the printer screen and it was functioning normally! Perhaps the computer reset something in the printer. Your results may differ, but mine is now working like new.
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
I have hp photosmart 145. Green light is on,memory card is inserted,no pictures are shown.Please help. Thank you. Pamala Barber
Hi!
Maybe the printer cannot recognize that specific file extension, what extension does the images have?
Jun 17, 2016 | HP PhotoSmart 145 4 x 6 Photo Printer
Alternative printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=305312
Jul 27, 2015 | HP Photosmart 435 & HP Photosmart 145...
I am using a stand alone photosmart 8450 ( with out computer ) it will print every memory card except SDHC the cards are fine as I use them in my Pentax camera
The 8450 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. SD cards will work in SD and SDHC devices, but SDHC cards will not work in SD devices.
Feb 27, 2011 | HP Photosmart 8450 InkJet Printer
Jammed scanner
Please make stand alone copy from your unit and verify whether the unit scan properly. If not please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00860153&cc=uk&lc=en&dlc=en&product=3192753
If the issue persists, please replace your printer as this is a hardware issue with the scanning mechanism.
:) Dr Tony
Apr 20, 2010 | HP Photosmart C4280 Aio Printer
How do you clean the ink jets
if it isn't broken, don't fix it. I would leave well enough alone until the printer starts giving you trouble.
Mar 13, 2009 | HP Photosmart C3180 All-In-One InkJet...
Driver for hp photosmart 145
http://www.driverslab.com/drivers/Printer/HP/Photosmart_145_5_1-Windows_98_Me_2000_XP/2483.html go to this site and you can download it from here
Nov 11, 2008 | HP PhotoSmart 145 InkJet Printer
I have lost the software for my hp photosmart 145 printer. and need to install it on to my new computer
You can download the drivers for the Photosmart 145 from HP's website here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 25, 2008 | Office Equipment & Supplies
HP Photosmart 145 printer
Hi All
I know there''s a lot of typing here, but just wanted to be thorough for those who may not be as handy at repairing. It really was quite simple and only took about 10 minutes.
My screen was only either blank or had black bars on top and sides of screen with all 8's in the centre of the LCD. I tried everything I found online to no avail, finally I got ********** & did what I usually do when things don't work...I took it apart (funnily enough it almost always does the trick)!
1-You'll need fairly small hex bits or allenkeys. There are 2 sets of screws both of different sizes of course.
2-Take the 2 screws from the bottom out first & that will allow enough leeway/gap to take the top silver panel off (surrounding the buttons & LCD).
3-You will find 2 more screws underneith this panel.
4-Once all 4 screws are out, you'll need a small flat-bit screwdriver or something that you can "pry" the plastic case off with. Of course I need not tell you to do this carefully so that you do not crack the plastic. There are a couple of plastic nibs to hold the plastic in place on either side of the tray, once you pry this off you will see the nibs in back.
5-Now, just pull the LCD screen straight out, it has pins that make it a plug of sorts...much like that of the old printer cables that plugged into the back of a desktop.
6-I simply blew onto the pins and into the plug-like holes in the event dust was impeding connection.
7-Then while viewing from the front of the printer I carefully lined up the pins & gently pushed until it was secure.
8-I then put the SD picture card from my camera in & turned it on before reassembling and...VOILA it worked!!
9-Obviously you put the screws back & when you are putting the top panel back on be sure to tuck the "finger-like" plastic nibs back in so as not to break them.
I hope this works for all of you!! I spent over 4 hours searching online, as I'm sure all of you did, only to find that many people had this problem with little answers.
Good luck to all of you...let me know how you do
Nicole
Aug 15, 2007 | HP Photosmart 435 & HP Photosmart 145...
HP PhotoSmart 145 InkJet Printer Logo
201 people viewed this question
Seeker5211
Seeker5211
