Question about Kenmore 24032\24036 Top Load Washer
Will not spin
Filled it back up ,not the water will not drain out ,all we get is a humming noise
  • kendraporter Jan 02, 2009
    washer want spin
  • Anonymous Jan 03, 2009
    Water won't drain, tub doesn't spin and I get a loud clicking noise when it tries to engage
Spin cycle has to be turned manually in order for spin cycle to work. what is the solution to this proble?
Posted on Jan 02, 2009
Ge GTWN2800D1WW washer wont fill on start but will do drain and spin
What do you mean? It not fill up or no water is coming in?
Did you hear some humming noise?
Check the input water tap... close be closed or blocked...
Dec 01, 2015 | GE Washing Machines
Lg wm2277 does not drain or spin
if it does not drain it will not spin humming noise is probably something jammed in the drain pump if youre machine has a clean out you can access the inlet to the pump and clean out the debris from there if not you will have to pull the hose off . if you bail as much water as you can from the tub and tilt the machine back at a good angle it will be possible to get to the pump without having to get a shop vac to clean up the water after words.
Apr 07, 2014 | LG WM Washing Machines
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
My GE washing machine is stuck on agiation mode.
Jul 15, 2009 | Washing Machines
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal De
 Brian Main
Brian Main
