Question about Dishwashers
Amx 1300 hobart dishwasher is not cleaning dishes
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
Posted on Aug 24, 2008
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
heatman101
  • 43501 Answers
SOURCE: amxx1300 dishes are coming out cold.
Check your heating element..
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
  • 119 Answers
SOURCE: Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Posted on Jul 16, 2010
Hobart glass wash machine AMX-GH wash with normal temperature but do not advance to rinse cycle
Can you describe the sequence of operation?
Fill ok?
Booster or tank heating ok?
wash pump running ok?
Sep 28, 2016 | Hobart Underbar Glass Washer
Hobart glass wash machine amx-gh continue washing does not advance to the rinse cycle with no error code
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
Sep 22, 2016 | Hobart Dishwashers
Hi I have a Hobart amx-16 quite an old machine now... when I pull down hood to start cycle, indicator comes up FIL.... during its cycle.... any advice please? Is there a reset function
This sounds like the dishwasher's filter might be clogged. It should be located under the bottom dish rack. It's fairly easy to disassemble. Just remove it and clean it out. Also, check under the filter to make sure there isn't any more debris and/or lime deposits there as well.
I hope this helps! :)
Jun 11, 2014 | Dishwashers
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Jun 04, 2009 | Hobart Dishwashers
Bof error hobart amx
Aug 16, 2008 | Dishwashers
Hobart amx/aux-s dishwasher "bof" error code
Mar 13, 2008 | Dishwashers
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
