Question about RCA HD52W56 52" Rear Projection HDTV
RCA 52" HD Widescreen
TV won't come on after moving it. The power button's green led lights up for about 10 or 15 seconds then shuts off. Nothing ever appears on the screen. You have to unplug it at that point and plug it back in to get the green light to come back on when you press the power button. Anyone have any ideas? It's about a year and a half old and has worked perfectly until I moved it. It was moved very gently. Thanks, Steve
PROB THE INSTANT ON IS BROKEN
Posted on Nov 13, 2007
  • 76 Answers
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
Posted on May 23, 2007
SOURCE:
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Powers on and then right back off
Try and clean the two filters on the tv this should be the first thing to do.
Feb 01, 2008 | RCA HD52W58 52" TV
52" RCA HD capable projection tv won't stay on!
This set has a processor that is telling the set there is a safety problem and shut the set down. this could be one of about 35 different cuiricts. Are there any sounds clicking chirping? An rca technician have special computer interfaces that can read errors generated by the processor that can help in determining what is wrong with your set.
Jan 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
137 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
