Question about Dell Inspiron 6000 Notebook
Had to power off my dell laptop due to it freezing now it wont
Now it wont reboot and repair..when i powered back on, the screen for reboot and repair came up but when i press the enter key (or any key for that matter ) it will not respond. Before it was shut down, it had been in hibernate ..i powered back on and it was running slow, ran virus scan and attempted to defrag but both kept running ..therefore i closed them.then it would not recognize any command..keyboard or pad..control/alt/delete......etc..can anyone help..
    Genius:
  • Dell Master
  • 1,102 Answers
Press f8 on restar and get into safemode
do a disk defrag then restart
let me know if this allowed you on if not we can do another solution
were you trying to do a virus scan and defrag at the same time
Posted on Feb 13, 2009
Dell inspiron m5030 freezes and screen goes black
It could be the graphics processor is having troubles. Try updating the graphics drivers.
Jan 18, 2013 | Dell Inspiron M5030 Laptop
Hi there, Our Dell Inspiron 1525 specs are as follow: Windows Vista Home Basic Service Pack 1 Intel Core 2 Duo T5750 @2GHz 2GB RAM - 32-bit OS Symptoms are: - Freezes oftenly after random period...
Do you have any CD's thatcame with your laptop? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.The blue screen of death can be caused by hardware or software. If Diags pass you probably have a software issue. If you don't have the resource CD press the key while powering the system on. This will run theDell built-in Diagnostics.
Feb 22, 2011 | Dell Inspiron 1525 Notebook
Screen wont turn on. Laptop is on but screen remains black...... padlock with 9 on it is flashing
Hi bernmurphy,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Dell Vostro 1500 Notebook
Macbook pro screen boots to black. tried rebooting, screen comes on then goes black again. This happened after I unplugged it from a dell projector. Any suggestions???
Try pulling the battery out then holding the power button for 10 seconds. Put the battery back in.
If not search macbook pro recall apple has extended the warranty on some models due to a bad graphics card.
Feb 02, 2010 | Apple MacBook Pro Notebook
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
N/book dell inspiron 1525 locked as cant be on every thing is ok cant switch on
presario 2200 screen freeze at "screen saver" picture...I've tried to reboot and to restore and repair...I can see files if I go into TASK MANAGER...but nothing will open...I get error beeps
Oct 24, 2009 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
Running with AC power, my Dell Inspiron 9400 would randomly show the Blue screen. After a few times of rebooting, I could see the Windows logo with horizontal white lines about 1 " long. Eventually the...
it was a brilliant laptop ever manufactured. check the costing. for the new laptop as well as the warranty pricing. Yes it is worth repairing, if you can manage the cost. becasue extending warranties would be a cheaper option. The LCD needs to be repalced in your case.
Oct 02, 2009 | Dell Inspiron 9400 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Laptop died won't boot
try changing the RAM if it helps otherwise
ur Hard Disk is getting weak backup ur data and try replacing ur Hard Drive check hard disk strength with HDDLIFE from www.binarysense.com
Dec 29, 2008 | Dell Vostro 1500 Notebook
Dell Inspiron 6000 Notebook Logo
64 people viewed this question
Alun Cox
