Question about Dishwashers
DISHWASHER NOT CLEANSING PROPERLY
KITCHEN AID PRODUCT... SOAP LEFT IN DISPENSER.. DISHES NOT CLEAN ESP TOP RACK
  • navy2 Jan 02, 2009
    what is an impeller intake... where is it??? mkr
  • 71 Answers
There is a food shreder located in the pump at the impeller intake, it looks like a round screen with a rotating blade on it, if the blade breaks off then the screen gets cloged and will restrict water flow.
Posted on Jan 01, 2009
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack of dishes is not clean
start by cleaning the dishwasher itself. then you may discover that you are putting objects in invorrectly and the rotars are not spinning correctly or at all because being blocked. also you may want to try a stronger detergent/soap
Aug 06, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Soap is left in the dispenser and the top rack doesn't get clean.
the inlet water pressure need to check i think there is weak level of water , check 1st nearest tap to sea normall flow of water is good or not ?
> if it is weak so the problem outside the dishwasher it is plumbing problem
>if it is good so the problem relate to dishwasher so chech the whole path of inlet water> i think this will solve the problem
thanks
Jul 13, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen aid NOT CLEANSING DISHES
It sounds like you are not getting enough water to make the dishwasher function effectively. Could be a bad valve could even be that the spray arms aren't letting through enough water.
Jan 01, 2009 | Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
