Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
I can't get my double oven to self clean.
I have cleaned it before with the self clean feature. Now I can't get it to lock and clean. I have tried everything. Any suggestions???? I can't find my manual.
    Problem Solver:
  • 15 Answers
Try shutting off the main breaker for a minute or so and then turn it back on and set the clock. It worked for me. I've had to repeat it the next time I self clean though.
Posted on Jan 03, 2009
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
May 31, 2007 | Frigidaire GLEB30T9D Electric Double Oven
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
135 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
