Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Unable to adjust temperature with control dial
I have a Frigidaire Upright Freezer Model # FFU14C3CW1 that has not been used or plugged in for about 6 months. It lost power due to a breaker trip while I was in the hospital. I have cleaned it out and I am now trying to use it but it is stuck on the coldest temperature. I have tried adjusting it by turning the control valve to warmer but this is not helping. Please tell me how I can repair this problem. If a new part is needed please tell me what it is that I need.
  • 700 Answers
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Posted on Jan 01, 2009
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What is the normal temperature setting for a ge upright freezer, dial from 6 to off?
Your need to use a thermometer and adjust the dial till you have between 0 and 10 degrees.
Jul 10, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
My freezer keep running all the and everything frozen but will not cut out. cannot find a dial inside to turn it behind.
dear sir /madam
please find the thermostat setting controller in your freezer,s inside of door and on the control panel after make reset it on correct temperature .
i hope after that it will work with temperature setting.
hope answer the question
thank you
please vote!
Aug 18, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
266 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
